Looking for beta testers to test HouseAgent
Introduce home automation related software here.....
Re: Looking for beta testers to test HouseAgent
Postby deraaij » Sat Jul 02, 2011 6:27 pm
Mdamen wrote:I'm proud to announce that the first beta version of HouseAgent is available here for testers: http://www.houseagent.nl/forum/viewtopic.php?f=4&t=16
Congratulations!
Mark
deraaij
Postby Noel » Tue Aug 09, 2011 7:45 pm
Not sure if βeta testing is still open, but if so I would love to have a go at it.
Noel
Postby Mdamen » Tue Aug 09, 2011 8:28 pm
No problem, just register on the forum and I will give you beta access!
Mdamen
Postby Noel » Tue Aug 09, 2011 8:37 pm
Mdamen wrote:No problem, just register on the forum and I will give you beta access!
Done... I'm "guest" on your forum :-)
Noel
Postby mishoboss » Mon Aug 15, 2011 4:33 pm
Seems to be really good start. Do you plan KNX integration?
mishoboss
Postby CLC » Mon Aug 15, 2011 8:24 pm
New beta tester on houseagent forum.
CLC
Postby Mdamen » Mon Aug 15, 2011 10:27 pm
@CLC, Noel: gave you guys access.
@mishoboss: there are no concrete plans for that yet, though it's a big upcoming market. I have zero experience with KNX so it would be nice if someone would pick it up.
Mdamen
Postby Alexander » Tue Aug 16, 2011 12:32 am
It would be a big plus plus plus if the system would have a visual/graphical flow chart in scenes. I'm familar with the VoIP PBX Swyx (http://www.google.nl/imgres?q=swyx+grap ... 80&bih=660) which has one and Vordel (http://www.google.nl/imgres?q=vordel+fl ... 80&bih=660). The examples have nothing to do with HA, but the idea is the same.
Would this be possible? Than you would not have to have those standard way of options to create a event, based on pre defined options. (In Swyx and Vordel you have also the option, if the predefined blocks don't help, to use a scripting block (in which you put the scripts that must run.)
Alexander
Alexander
Postby Mdamen » Tue Aug 16, 2011 9:31 am
That's a great idea, thinking of events as flow charts!
I found a javascript library that does some of the work: http://neyric.github.com/wireit/
An example: http://neyric.github.com/wireit/plugins ... index.html
Mdamen
Postby Noel » Tue Aug 16, 2011 10:32 am
Anyone here coding a X10 plugin for HouseAgent?
Noel
Postby keeslamper » Mon Apr 23, 2012 10:27 pm
Are you still looking for testers? I want to test with Z-wave if you want. I'm looking for software to try, I'm a newbie!
keeslamper
Postby turboproc » Thu Jul 19, 2012 7:57 pm
I would be pleased to contribute by testing. Please provide my with the latest Jeenode plugin. I've the impression that the plugin at GitHub is not aligned anymore with the API in the latest version of HouseAgent. That allows we to start testing with the Jeenodes that shoud arrive next week. Furthermore I should investigate what's needed to simply include the YouLess sensor into HouseAgent.
I'l be running HouseAgent in a Linux Gentoo environment. That part of the installation has in fact been completed without to much trouble.
turboproc
Previous
Return to Announcements & News
