Audio over IP with dedicated card
Hi all, on next May, i will have some cards like this to implement my home audio system over lan cables. the system consist of minimum 2 cards connected with cat5 cable (one transmitter , one/many receiver). transmitter gets audio from a source like : a pc , mp3 player.......
i was thinking about HS server sending some audio files on certain conditions , or else.
Re: Audio over IP with dedicated card
Nice card drmacchi. Thanks for sharing.
futurashop.it/carrello_sql/prodotti.asp ... FT859M.jpg
Verkenner
Verkenner
Best regards, Verkenner
I think that this card could solve many situations : ready to use , simple connections, usable over ip and internet too. a blockbuster for our audio needs ?
I also have a small audio company.
This is very useable for me!!!!
This is the first unit that i see that does a AD/DA conversion and uses TCP/IP
(i also am a network engineer with the Department of Defense, so i am glad to be able to combine audio and networking)
Very interesting little device!
@drmacchi
My italian is very, very bad....., but i am very interested and would like to order 2, but i can't discover an email adres on the site.....
Could you please send me an emailadres?
The shop has online shopping : www.futurashop.it
direct contact :
ordine-at-futurel-dot-com
info-at-futurashop-dot-it
direct contact :
I have bought 2 boards : they are the same and you can set (client/server) with a jumper onboard.
CLIENT (yes it seems a mistake, but this is the name given by producer) SENDS AUDIO
SERVER RECEIVES AUDIO
client and server can be on same lan , or connected by tcp everywhere, even with dyndns service !
my setup consist of :
+2 boards ,
+a router (same lan),
+an audio source (connected to client board) that is a old notebook with windows millenium (!) running a mp3 on usb stick. why such old pc ? becuase my ultra-mega super power notebook has only SPDIF audio out.......... and i can not test a mono audio signal with that.
+a speaker set connected to server board, only one speaker will work because i made a mono connection , just to test.
BOARDS : you explore them with a DISCOVERER TOOL you set using a browser : menu is very complete ! : authentication (set password...) , local network , remote network, dyndns, plugin upload etc.
plugin : what is that , should be eproom files with various settings of audio , i have 3 of them , but didn't upload anything new because with the preset works vey good How good is audio quality ? GOOD ! i did a movie but what you'll hear is not that good , like i hear because my handycam is a cheap one ! and settings was MONO not stereo
Later i will post YOUTUBE VIDEO
+2 boards ,
- dyndns.JPG (78.11 KiB) Viewed 25851 times
- settings-server.JPG (75.99 KiB) Viewed 25851 times
I'm waiting fo someone that is able to create it !:)
Video .
BOARDS :
boxes are DIY.
BOARDS :
boxes are DIY.
PLUGIN TYPES (alias eproom)
venc16k2q05.bin: versione stereo con frequenza di campionamento a 16 kHz
- venc44k1q05.bin: versione mono con frequenza di campionamento a 44 kHz
- venc44k2q05.bin: versione stereo con frequenza di campionamento a 44 kHz
The first is for general purpose , the third is for the best audio quality.
cheers,
Lorenzo
cheers,
Lorenzo
Lorenzo, GREAT !
You made even a reality soap om Youtube ! Great.
Thanks for sharing.
Regards, Verkenner
Thanks for sharing.
Regards, Verkenner
No no , that's my friend's wedding of last saturday ! that's not a domotica convention
