Bwired Googlemaps upload data webservice
Postby esschenk » Mon Apr 20, 2009 9:44 pm
Hello Pieter,
No the caracters are below 40
It was a problem with the script
Paul has made version 0.8
now everything is working perfect.
Paul Thanks for the script now my url is showing on the Map.
Thanks ed
<font size="1">
esschenk
Postby Lennart » Mon Apr 20, 2009 9:44 pm
Paul, thanks for adding the last changed date / time of the device and fixing the issues! Everything works great for me.
Lennart
Lennart
Postby Sooty » Mon Apr 20, 2009 9:48 pm
I suppose the next issue will be that 20 devices is not enough :-)
Paul..
Sooty
Postby Lennart » Mon Apr 20, 2009 9:49 pm
Didn't want to bother you with that ;-).
Lennart
Lennart
Postby Sooty » Mon Apr 20, 2009 9:58 pm
Initially Pieter asked me to limit it to 10 devices. This was then increased to 20, but I can increase it to 30 or more if Pieter is OK with that.
Paul..
Sooty
Postby Lennart » Mon Apr 20, 2009 10:14 pm
OK, let's see what Pieter says. Of course, it's not really required (but fun nonetheless :-) as 20 devices should be enough to show on the map that you're house is wired. Adding more devices will add some display challenges as well. Furthermore, as people can send an XML file without using your plugin, Pieter must limit (and therefore change) it at the receiving end as well.
Lennart
Lennart
Postby esschenk » Mon Apr 20, 2009 10:28 pm
Hello Paul,
Is it possible to rearrange the devices so let say I want the first device on position 4
Now I must delete the device and make a new one
It is not u must but it can be handy.
ed
<font size="1">
esschenk
Postby Sooty » Mon Apr 20, 2009 10:52 pm
Ed,
This is on my to do list. I started this before I went on holiday, but never got it finished.
I will try and get it finished this week some time.
Paul..
Sooty
Postby Bwired » Mon Apr 20, 2009 11:06 pm
There is no limitation on my side, the script is generic.
25 or 30 is OK with me, only the po-pup on the marker gets bigger.
I also have showing High Low Values of the day on my ToDo list, as you you know I can extract those as wel.
The sorting can be handled with the <Sortid>.
Thanks all Specially Paul!
PS: Welcome JCW on the map!
Postby Sooty » Tue Apr 21, 2009 12:01 am
Ok Pieter, I will increase the number of devices to 30.
Ed,
Does this type of sorting look OK for you? you can move an item up or down the list which will change its ID number. I have created the buttons, so if this looks OK, I will add the code to do the sorting tomorrow.
I have also added a column for the ID number of the device.
Paul..
Sooty
Postby esschenk » Tue Apr 21, 2009 12:14 am
Hello Paul,
Great this is what I mend
Thats working perfect for me
Thanks
Ed
<font size="1">
esschenk
Postby Esteban » Tue Apr 21, 2009 12:19 pm
Another great addition, thanks Paul.
Ciao,
Esteban
Esteban
Postby Hetwieg » Thu Apr 23, 2009 11:02 pm
I am just thinking about the icons and it would be nice to chance the icon to a special icon for HomeSeer or Domotiga or something else.
then you can see where it is use.
(It is only one suggestion)
Hetwieg
Postby Ruud » Wed May 20, 2009 12:46 am
Paul,
Can you ad a last change (date/time) field for the rfx virtual device? It's nice to know when the lowest/highest temp has occurred
gr Ruud
Ruud
Postby Bwired » Wed May 20, 2009 1:21 am
Hi Ruud,
I can show this, from your uploads I store high low values.
PreviousNext
Return to Bwired Forum
cron
