Wireless Weightscale from Withings
Postby Bwired » Fri Oct 09, 2009 5:41 pm
Last week I received a WIFI (Wireless 802.11g) demo weight scale from www.withings.com.
The scale looks absolutely great and has a very nice design!
Installing is very easy, just plugin the USB Cable go the withings website and follow the installation guide. The scale and router settings are automatically set from the website (WEP/WPA/WPA2-personal security)
You have a personal secure website with Withings and there is also an API tool available at
http://www.withings.com/en/api to get the data automatic from the website to your own environment.
I have been discussing this option with the supplier and asked him why not a sort of IP notification so geek like us can receive the readings realtime in our own applications or website. Withings promised this option to be available very soon (lets hope!)
There is also a free Iphone app available
ITO Invisible electrodes
Fat mass
Lean mass
Body mass index
Instant weigh-in by getting on the scale
Automatically turns on and off
Automatic user recognition
Comparison to reference values dictated by doctors
Check my blog also
http://www.bwired.nl/weblog.asp?id=337
Postby Snelvuur » Fri Oct 09, 2009 6:02 pm
Nice, i looked at this once, but there was no option to hook it up (you need there service) but then again for now there is nothing wrong with the oregon scale ;)
Snelvuur
Postby Alexander » Fri Oct 09, 2009 6:19 pm
If i had this scale to test, i would sniff the traffic and look in to the packets that are send and if it's based on a FQDN destination host, i would write my own service and add the FDQN host in my DNS server.
Alexander
Alexander
Postby Digit » Fri Oct 09, 2009 6:55 pm
Could have been my idea [:D]
Postby Bwired » Fri Oct 09, 2009 6:55 pm
Agree the Oregon has a direct link to my own system, but If the IP notifications comes......
@mgizmo: Tell me how to sniff my router and I will try, otherwise contact me.
Postby Alexander » Fri Oct 09, 2009 7:08 pm
@pieter: Uh Fritz!Box? http://domoticaforum.eu/topic.asp?TOPIC_ID=3194#26497
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">network sniffer is default available: /html/capture.html<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Alexander
Alexander
Postby Bwired » Fri Oct 09, 2009 7:24 pm
Is it detailed enough, I have systools for my draytek router but is only giving me IPnr's and ports etc.
Postby Digit » Fri Oct 09, 2009 7:48 pm
I think you would need to look for DNS queries in outgoing connections for xyz.withings.com or other unusual hostnames with Wireshark. Although i'm not really good at these things that would be my first try.
Postby Bwired » Fri Oct 09, 2009 8:52 pm
I tried wireshark but can't select my router with it :-(
Postby Rene » Fri Oct 09, 2009 9:41 pm
Do you have tcpdump available on your router?
Postby mhn » Fri Oct 09, 2009 9:59 pm
The problem with Wireshark is, you have to make your network traffic pass your Wireshark computer, unless you can make a monitor port on your switch/router.
mhn
Postby Digit » Fri Oct 09, 2009 10:17 pm
Or put your Wifi Access Point and PC with Wireshark on the same collission domain, that should work i think (it used to)
Postby Bwired » Fri Oct 09, 2009 10:39 pm
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rklootwijk</i>
<br />Do you have tcpdump available on your router?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">No I don't
Postby Rene » Fri Oct 09, 2009 10:44 pm
Maybe you can find some information about setting up a span or mirror port on your draytek (e.g. http://www.retrevo.com/r/23281bh938/29/Mirror/). Then you could run Wireshark on that port.
Postby mhn » Fri Oct 09, 2009 11:48 pm
Hmm Wifi is a hub. It should work sniffing if Wireshark is on the same Access Point.
I don't know about encryption though.
(I am used to have access to the right places on the network. :-) )
mhn
Next
Return to Bwired Forum
