Water Sensor project
Postby Bwired » Sun Feb 10, 2008 2:48 am
I got this water Sensor from Greisinger type GEWAS 191A which can be installed between the wash machine and the water. It has 2 sensors which can be placed on different positions. If the (leaking) water hits the sensors the water is disconnected and a loud buzzer will go off.
http://www.greisinger.de/files/upload/d ... kat/98.pdf
For now a day's this is good device to have, I think there are a lot of people out there who had waterfloods in the past!
I adjusted the device, put a mini relais (12 volt) over the buzzer. The relais is activated when the sensors detect water. So now I'm able the check the status of the sensor and and mail or SMS when something goes wrong.
attach the small relais in place
You can connect this to any device you want like Visonic, Xanura or Poseidon etc. I think the sensor can be delivered by Conrad
Simple and usefull
check http://www.bwired.nl/Devices.asp device V23
Pieter Knuvers
Postby Snelvuur » Sun Feb 10, 2008 12:14 pm
Put it in the bath tub, once its at a certain level, you can warn yourself that its time to go to bath.
Snelvuur
Postby Dowser » Sun Feb 10, 2008 1:08 pm
Personally I like to have a warm bath, and I think that the steam condensing on the electrodes easily will trip the relay, and then you got a puddle instead of a bath, that won't continue to fill untill you have dried off the electrodes carefully. :)
//Markus
Dowser
Postby Bwired » Sun Feb 10, 2008 1:34 pm
Right, the sensors are very sensitive. And really no option to mount these sensors in my bathtub... esthetically :-)
Postby DJF3 » Mon Feb 11, 2008 1:08 pm
Would it be possible to connect a Visonic MCT-100 to the buzzer? (or doesn't it accept/handle the voltage that it will receive?)
Thanks
DJ
DJF3
Return to Bwired Forum
