Homeseer reboot
Homeseer reboot
Laatste paar dagen is mij HS spontaan gaan rebooten.
Enige error die ik in eventviewer terug kan vinden is het volgende.
Systeem draait gewoon 24 uur per dag geen gebruikers zit op het systeem
Veranderingen op de server:
PHNetwork plugin .45
ADito VPN server services
Adito staat nu tijdelijk uit.
Iemand een idee wat het kan zijn?
Details
Product: Windows Operating System
Source: Userenv
Version: 5.2
Symbolic Name: EVENT_HIVE_SAVED
Message: Windows saved user %1 registry while an application or service was still using the registry during log off. The memory used by the user's registry has not been freed. The registry will be unloaded when it is no longer in use.
This is often caused by services running as a user account, try configuring the services to run in either the LocalService or NetworkService account.
Explanation
Windows unloads each user's profile and user's section of the registry when the user logs off. This message indicates that Windows could not unload the user's profile because a program was referencing the user's section of the registry. This locked the profile. The registry cannot unload profiles that are locked and in use. When the program that is locking the profile is no longer referencing the registry, the profile will be unloaded.
User Action
No user action is required.
Related Knowledge Base articles
You can find additional information on this topic in the following Microsoft Knowledge Base articles:
Event ID 1054 is logged in the Application log in Windows Server 2003 or in Windows XP Professional
The following event may be logged in the Application log: The client computer may also experience a very slow logon.
Error Messages About User Profile Appear in Several Logon Situations
Under the following circumstances, a user may encounter several error messages that concern profiles: The user account is configured to use a roaming profile.The user is logging on to the domain over a slow connection, for example, by using...
Using the Symantec W32.Nimda.A@mm Virus Removal Tool Affects the Sysvol and Netlogon Share Permissions
When you use the Symantec W32.Nimda.A@mm virus removal tool on a domain controller, the share permissions for shares such as Sysvol and Netlogon may be changed from the default share permissions. The application log may display the following error...
DNS, Intersite Messaging, Global Catalog, NTFRS, and "Invalid Credentials" Error Messages on Domain Controller
On a domain controller that runs Windows 2000, Event Viewer may log the following Domain Name System (DNS) events every 12 to 15 minutes: Event Type: Error Event Source: DNS Event Category: None Event ID: 4000 Description: The DNS server was...
Cannot connect to domain controller and cannot apply Group Policy with Gigabit Ethernet devices
Windows XP-based systems that use Gigabit Ethernet devices may not be able to log on to an Active Directory domain, which aborts the Group Policy download process. When this occurs, a series of events are written to the event log. For example: -and-
Event ID: 1517 occurs when users who use roaming profiles encrypt files on a Windows Server 2003-based file server
Fixes the problem in which Event ID 1517 occurs on a Windows Server 2003-based file server. When users who use roaming profiles encrypt files on the file server, miniprofiles are created. These profiles may not be deleted.
Warning error 1517 in Event Viewer after first restart
Explains the presence of an event log warning that appears when you first restart the computer after you install Windows XP.
The user profile may not be correctly unloaded when you log off from a Windows Server 2003-based computer, and event 1517 is logged
When this problem occurs, you cannot resolve it by using the User Profile Hive Cleanup Service. Occurs regardless of whether you log on to the computer directly, in a terminal server session, or in a remote console session.
Windows 2000 Roaming Profiles May Not Synchronize with Windows NT 4.0 Shares
When you log on to a domain using a computer running Windows 2000 and your profile is located on a computer running Microsoft Windows NT 4.0, the local and server-based profiles may not synchronize and the following event may be logged in Event...
You cannot start the Live Communications Server service on a Live Communications Server 2005 access proxy server
Describes an issue in which you cannot start the Live Communications Server service on a Live Communications Server 2005 access proxy server. Provides a resolution.
You experience log off problems on a Windows XP-based, Windows Server 2003-based, Windows 2000-based, or Windows NT 4.0-based computer
Discusses log off problems in Windows XP, in Windows Server 2003, in Windows 2000, and in Windows NT 4.0
Error Messages When You Open or Copy Network Files on Windows XP SP1 Clients That Require SMB Signing
Client computers that are running Windows XP Service Pack 1 (SP1) and that are configured to require Server Message Block (SMB) signing may drop SMB signing and may have problems communicating over your network. For example, you may experience any of...
Cannot Access Group Policy Objects--Event ID 1000 and Event ID 1001 Logged
If the primary network adapter in a multihomed domain controller does not have File and Printer Sharing bound to it, multiple problems are logged or displayed when you attempt to work with Group Policy objects on the domain controller. The...
You may receive an "Object not a collection" error message when you try to use the stdregprov class in WMI to read values in the HKEY_CURRENT_USER (HKCU) registry hive in Windows Server 2003
Describes a problem that may occur in Windows Server 2003. You may receive an "Object not a collection" error message when you try to use the stdregprov class in WMI to read values in the HKEY_CURRENT_USER (HKCU) registry hive
The DNS suffix of the computer name of a new domain controller may not match the name of the domain after you upgrade a Windows NT 4.0 primary domain controller to Windows 2000
Describes a problem where a domain controller's domain name system suffix does not match the domain name. To resolve this issue, install the latest service pack for Windows 2000, or upgrade the domain controller to Windows Server 2003.
Twitter http://twitter.com/Chak64%20My%20Domoti ... tane.nl/wp</font id="size1">
Bastiaan
Homeseer reboot
Post by Bastiaan »
Heb je Homeseer als service draaien? Zo ja, probeer het eerst eens op de "gewone" manier.
Alexander
Homeseer reboot
Post by Alexander »
Deze HS server draait virtueel toch? Ik heb een server bij TransIP in het datacenter staan en daar draaien ook een aantal virtuele machines op (via VMWare Server). Die rebooten ook spontaan. Ik vermoed dat dit komt door een fysieke disk die direct is gekoppeld aan de virtuele machines.
Het klinkt in ieder geval dat het buiten je OS ligt (en ik neem aan dat de server niet netjes reboot, maar echt uitvalt).
Alexander
Bastiaan
Homeseer reboot
Post by Bastiaan »
Ha hebben we het hier nou over een HS programma wat reboot of over een VM die reboot?
Homeseer reboot
Het gaat om een fysieke machine.
reboot is nu bijna elke uur.
Voor de reboot zie ik wel dat een aantal processen worden afgesloten oa. irtrans.
Ik kan niks terug vinden wat mogelijk een oorzaak is.
Alexander
Homeseer reboot
Post by Alexander »
Enver, het systeem sluit dus wel netjes af?
edit: gebruik process monitor eens om te loggen wat er allemaal gebruikt wordt, zodat je kunt achterhalen welk proces het systeem herstart.
Alexander
Homeseer reboot
Echt netjes is het ook niet..Homeseer gaat wel onderuit
Hoe kan ik met Proces monitor zien wat voor herstart zorgt?
6-11-2009 13:40:08 ~!~Device Update~!~Device: Z-Wave Interface Badkamer Badkamer Radiator Battery Battery Level 56%
6-11-2009 13:40:37 ~!~IRTrans Error~!~Connection to localhost has been broken.
6-11-2009 13:40:37 ~!~IRTrans Error~!~Connection with IRTrans Server broken; will periodically attempt reconnection.
6-11-2009 13:44:29 ~!~Startup~!~
6-11-2009 13:44:29 ~!~Startup~!~********************************************************************************
6-11-2009 13:44:29 ~!~Startup~!~ HomeSeer version 2.3.0.137 Starting Now (PRO Build)
6-11-2009 13:44:29 ~!~Startup~!~Using system's regional settings
6-11-2009 13:44:29 ~!~Startup~!~Creating Class Objects...
6-11-2009 13:44:29 ~!~Startup~!~Loading Settings
6-11-2009 13:44:29 ~!~Warning~!~HomeSeer was not shut down successfully the previous time it was started.
Willem4ever
Homeseer reboot
Post by Willem4ever »
Komt het niet door de Homeseer watchdog ? Zet die eens uit en kijk wat er dan gbeurd
Homeseer reboot
daar had ik nog niet aan gedacht...goed plan
heb net de restore point terug gedraaid...als naar 29/10
zal na herstart hs-senety ook uitzetten..
Homeseer reboot
Willem..het is dus toch HS zelf.
Heb het gevoel dat hun tool niet lekker werkt.
http://board.homeseer.com/showthread.ph ... post893957
nu even naar de optie zoeken om HSSentry uit te zetten..meer last van dan dat het echt helpt.
Darwusch
Homeseer reboot
Post by Darwusch »
Volgens mij is er geen optie om HSentry uit te schakelen.
Zelf heb ik de twee exe files die voor de restart verantwoordelijk zijn aangepast, zodat de restart niet meer plaatsvindt.
snowboarder
Homeseer reboot
Post by snowboarder »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by darwusch</i>
<br />Volgens mij is er geen optie om HSentry uit te schakelen.
zou je mij kunnen vertellen hoe je de exe bestanden hebt aangepast
zodat er geen restart meer plaats vind ?
Marcel
www.myhomecontrol.nl
Darwusch
Homeseer reboot
Post by Darwusch »
Indien mensen hier bezwaar tegen hebben dan wordt dit uiteraard verwijderd.
In HS2Sentry.exe staat een functie CheckFromTimer, waarin de reboot wordt aangeroepen.
Je kunt met een hex editor de volgende adressen op 00 zetten:
Voor HS Pro versie 2.3.0.86:
191A tot en met 1920 (dat zijn dus 7 posities)
Voor HS Pro versie 2.4.0.0:
296A tot en met 2970 (dat zijn dus 7 posities)
In HS2SentryService.exe staat een functie CheckTimer, waarin de reboot wordt aangeroepen.
In HS Pro versie 2.3.0.86 en 2.4.0.0:
1660 tot en met 1666 (dat zijn dus 7 posities)
Het enige wat dit doet is het reboot commando verwijderen.
Homeseer reboot
bedankt voor de tip.
vandaag is mijn HS 8 keer onderuit gegaan.
ik heb het nu via taskmanger gekild.
morgen maar de aanpassing doen
Ik gebruik versie 2.4
is het mogelijk dat je de exe file kan posten?
Darwusch
Homeseer reboot
Post by Darwusch »
Hierbij, de aangepaste files voor HS Pro versie 2.4.0.0 t/m 2.4.0.6.
Succes.
Download Attachment:
http://www.domoticaforum.eu/uploaded/da ... es_2.4.zip
