radiator valve
b_weijenberg
radiator valve
Post by b_weijenberg »
The smartwares radiator valve can be controlled by the RFXtrx433E (not by the RFXtrx433) This function is implemented in the latest firrmware version 233.
http://www.homewizard.nl/smartwares-dra ... kraan.html
vincenttor
Re: radiator valve
Post by vincenttor »
Very nice addition !
Thanks for the info
IF using this, are you able to set the temp from HS touch / homeseer ?
b_weijenberg
Re: radiator valve
This function will be implemented soon in the HS3 plugin.
Functions supported by the RFXtrx433E are:
- Set Day temperature
- Set Night temperature
- Set temperature (5 - 28 degrees)
vincenttor
Re: radiator valve
OK sounds great.
Thanks
Re: radiator valve
Phaeton
Re: radiator valve
Post by Phaeton »
Does the valve also provide information about its current setting?
groeten,
b_weijenberg
Re: radiator valve
The valve is a receive only device.
The current setting is visible on the module.
stefxx
Re: radiator valve
Post by stefxx »
I guess that it is not supported on my old LAN 2 COM 87005 transmitter?
Phaeton
Re: radiator valve
Post by Phaeton »
Tnx
groeten,
Re: radiator valve
stefxx wrote:I guess that it is not supported on my old LAN 2 COM 87005 transmitter?
right
