RFXmeter over LAN
RFXmeter over LAN
Postby Bastiaan » Wed Sep 24, 2008 10:04 am
Hi Bert,
Do you have any plans to create a RFXmeter in a wired version like using LAN?
I am asking because I have serious trouble getting any good reception in my house. The range of my RFXCOM seems very limited and my house is 40meters long......
Of course the stuff I want to meter is at the far end :-(
Bastiaan
RFXmeter over LAN
Postby b_weijenberg » Wed Sep 24, 2008 11:34 am
You can extend the range of the RFXMeter by changing the antenna wiring.
Open the RFXMeter, drill a 2mm hole in the enclosure at about 10mm next to the hole for the green LED.
Cut the yellow antenna wire at the bottom end (close to the 3rd module)
Feed the yellow antenna wire through the 2mm hole and close the RFXMeter.
b_weijenberg
Return to Rfxcom Receivers & Transmitters Forum
Users browsing this forum: No registered users and 2 guests
