rfxcom usb freeze
rfxcom usb freeze
Postby dimach » Tue Dec 23, 2008 8:53 pm
I have USB rfxcom with two receivers. Receiver with id 0 is X10 USA and receiver with id 1 is for Oregon Scientific.
The problem I have is that the receiver stops receiving signals after approximately 15 hours(can be more, can be less).
After I restart application, it works again.
I've tried latest heyu and my own php based application with the same results.
My app works in variable length mode. I assume the same is true for heyu.
Any suggestions? May be there is better firmware available?
Thanks,
Dmitri.
dimach
rfxcom usb freeze
Postby b_weijenberg » Tue Dec 23, 2008 9:30 pm
Is the receiver directly connected to the PC or on an USB hub?
I have seen this problem before with the receiver connected to a hub. When connected directly to the PC port it ran OK.
Do you have another system to connect the receiver to and run RFreceiver to see if it works OK for a long time?
It is not expected that a receiver firmware update solves disconnect problems. It is more likely that the USB hardware in the interface or the driver is not OK.
Go to http://www.ftdichip.com/Drivers/VCP.htm and check if you have the latest VCP driver version installed.
b_weijenberg
rfxcom usb freeze
Postby dimach » Tue Dec 23, 2008 9:57 pm
It is connected using hub. I'm using Debian Linux and the serial adapter is recognized by the kernel.
Unfortunately the system is 6000 km from me at the moment and I won't be able to reconnect it to direct port now.
I'll post once I try to connect it directly to USB port.
Thanks!
dimach
rfxcom usb freeze
Postby dimach » Mon Dec 29, 2008 11:38 am
The receiver was connected directly to USB port and it works fine for the last 28 hours.
Thanks!
dimach
Return to Rfxcom Receivers & Transmitters Forum
