Using multiple Oregon sensors:
Communication Failures will sometimes arise if you have 2 or more Oregon sensors of the same type and with the same channel selected. One or two sensors are sometimes not received for a period of a few hours. The reason is that they transmit during that period on the same moment. The interval time differs a very little bit for each sensor and the transmit period shifts slowly and at a certain time both sensors transmit on a different time again and are received again.
The solution is to select another channel on each sensor of the same type or use different sensor types.
Note: TEMP1, TEMP2 are different types but THR128 and THC138 are the same types as they are both TEMP1 sensors!
The THGR810 is a 10 channel sensor and you can use 10 of these sensors without having the Communication Failure due to sensor transmission overlap. An out of range is then the most expected problem. Don't install the sensors near metal objects because this can limit the range too.
It can still happen that sensors transmit at the same time when having different sensor types or different channels selected but not for a long period and Communication Failures will not appear due to this.
For Oregon sensor types see: http://www.rfxcom.com/oregon.htm
Multiple Oregon sensors
- b_weijenberg
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
