CO2 sensors
CO2 sensors
Postby mamruoc » Wed May 30, 2012 2:00 pm
Do anybody know about CO2 RFXComm sensors?
mamruoc
Re: CO2 sensors
Postby djdive » Thu May 31, 2012 8:46 pm
These are hard to find, At least I have not found them yet.
But there is a way to do it, i have use an old CO2 sensor that have a 0-10Vdc output signal that i have connect to a RFXsensor.
The RFXsensor have a A/D input that can measure this voltage and send it to the (in my case) Homeseer environment.
__________________
djdive
Postby Herbus » Thu May 31, 2012 11:18 pm
I suggest to messure CO. Messuring CO2 will give a lot of alarms :-)
Herbus
Re: CO2 sensors
Postby mamruoc » Thu May 31, 2012 11:33 pm
djdive wrote:Hi,
Nice, would never thought of this solution.
Do you have manufacture and model of the components you have used?
Brgds.
mamruoc
Re: CO2 sensors
Postby djdive » Thu May 31, 2012 11:35 pm
Why do you think that?
I messuring the CO2 to control the home ventilation so the air is fresh and clean.
When you have CO you have a bigger problem, something like fire ;-)
Grtz,
__________________
djdive
Re:
Postby mamruoc » Thu May 31, 2012 11:37 pm
Herbus wrote:I suggest to messure CO. Messuring CO2 will give a lot of alarms :-)
CO2. I would like to push fresh air when CO2 limit is triggered.
I know, I have survived sleeping in rooms with bad air, but when I first starting in into smarthouse solutions, why not?
mamruoc
Re: CO2 sensors
Postby Stevexyz » Fri Jun 01, 2012 9:21 pm
I'm using a Hanwei MG-811 for sensing CO2. It needs 6V at around 200mA (for the heater) and a very high impedance buffer and then it will give you an output of roughly 500-300mV for CO2 concentration of 350-10000ppm
You could feed that output after you've buffered it to an RFXsensor.
Steve
Stevexyz
Re: CO2 sensors
Postby simjoc » Sun Jun 03, 2012 1:01 pm
Ik kwam deze wel laatst tegen:
http://www.ezhome.nl/sensoair-z-wave-co ... model.html
Volgens mij is deze z-wave gebaseerd, niet echt goedkoop alleen.
simjoc
Re: CO2 sensors
Postby nico_gh2 » Sun Jun 03, 2012 2:10 pm
Visonic has a CO2 sensor at approx 130euros.
But you would need the Visonic addon to the RFXcomm as well and this is only for the LAN version available and not for the new USB unit.
Besides that I don't know if the Visonic sensor will report levels or just trigger an alarm at a certain level.
nico_gh2
Return to Rfxcom Receivers & Transmitters Forum
