Wireless power sensor (220v)
scasic
Post by scasic »
I'm looking for wireless power sensor compatible with rfxcom which can send information about power outage.
Could someone suggest me a model?
thanks
knasen17
Re: Wireless power sensor (220v)
Post by knasen17 »
That makes two of us! Conrad has one, but I dont think it is supported by rfxtrx433
b_weijenberg
Post by b_weijenberg »
connect this sensor and it transmits an ON command on a power outage.
http://www.klikaanklikuit.nl/shop/produ ... -awmt-231/
Moskus
Post by Moskus »
But is it a power sensor?
HSPro 2.5.0.60, X10 CM11, Z-wave Aeon Stick2, RFXCOM, Script Connector, BT connector, DI Connector, DooNetwork, HSTouch, Squeezebox plugin, iTach WF2IR & GC-100-6 with UltraGCIR, BLicon, DenonAVR, WebcamXP, Jon00s MaxiBee and Webpage builder
b_weijenberg
this module is normally connected over the contact of a wall switch.
If the switch is open the module detects 230V through the connected lamp and the module transmits an OFF command.
If the switch is closed the module detects no power and transmits an ON command.
Clever!
Moskus
Post by Moskus »
Oh yes, that IS clever. Is it possible to adjust the sensitivity?
scasic
Post by scasic »
looks like a applicable workaround! thanks for the answer
