Latest additions to RFXtrx433 firmware
b_weijenberg
Post by b_weijenberg »
RGB LED strip controller
With Lighting5 you can control dx.com RGB controllers
This one has a learn option and any ID can be used.
http://dx.com/p/rf-remote-touch-rgb-controller-130913
This one has a fixed ID and the ID of the remote must be used
http://dx.com/p/wireless-touch-panel-re ... ight-67412
Maverick ET732 Barbecue dual sensor
http://www.amazon.com/Maverick-Et-732-R ... B004IMA718
Livolo touch switch and dimmer
http://www.aliexpress.com/store/all-who ... 00715.html
be sure to select the RF version!
Elro - Byron SX chimes
http://www.chbyron.eu/Byron/ByronSXRange/68/89/
Revolt NC-5462 Energycounter
http://www.pearl.de/a-NC5462-5452.shtml
It is not advised to use this module if other 433.92MHz devices are used because this sensor transmits with a very short interval of about 4 seconds and the risk to disturb other RF traffic is too high.
Alecto SA30 smoke detector
http://www.alecto.nl/rookmelder-3-stuks-linkable
OWL CM180i sensor (3 phase current and total power usage)
http://www.planete-domotique.com/transm ... n-owl.html
http://www.planete-domotique.com/pince- ... ndard.html (10mm 71Amp)
http://www.planete-domotique.com/pince- ... large.html (17mm 200Amp)
Image Image
Re: Latest additions to RFXtrx433 firmware
nice additions!
Rebel
Post by Rebel »
Bert,
Is the Alecto "koolmoxide meter" COA-22 also incluided?
Arjo.
b_weijenberg
As far as I know the COA-22 is not equiped with RF
Rebel
Post by Rebel »
Ok, thanks
Verzonden vanaf mijn iPhone met behulp van Tapatalk
labium
Post by labium »
very nice additions, braking News for domoticaland. Integration of systems is a bad understood principle for some domotica suppliers but of the essence for their survival. I dont have 20 usb ports on my computer while some manufaturers think that. i dont want 20 wifi networks in my house but one. 1 wifi network can just cope with my family's demands of tablets, phones and computers. And i dont have the time nor the money to buy 20 different systems. And 20 different apps to monitor is also not what i expect from domotica. And least of all i want 30 remote controls in my house.That is what i like from rfxcom the underlying idea is integration= standardization .
raymonvdm
Post by raymonvdm »
Nice way of telling the new additions :-)
Keep up the good work :idea:
Dylantje
Post by Dylantje »
Great...
@ bert,
Are all the divices from livolo [ eu version 433Mhz ] supported?
And the give no bomb signal?
operate these switches as kaku versions.
Whether they work on the Zwave way.
I mean, so they give a 433MHz signal when I use them manually? [ i ordered 2 of these, 1 duo switch and 1 dimmer ]
How does the dimmer works?
This is a dimmer switch fitted as an old-fashioned?
Or should this dimmer dimming all lights a kaku or Zwave, with a extra lampmodule?
Templar
Post by Templar »
b_weijenberg wrote:Latest additions to RFXtrx433 firmware
FYI
domoticaforum.eu/viewtopic.php?f=27& ... 322#p66973
TechNovation
Post by TechNovation »
Good update.
After upgrading the firmware to release 71 the Oregon EW109 is correctly reporting the temp/humidity info.
I do have some issues getting the
to work.
I'm using the RGB TRC02 in the lighting 5 tab of the RFXmngr, but I don't know how to properly identify the fixed ID of the remote.
I do receive some of the rf signals send from the remote (some buttons pressed do not show up in the RFXmngr).
These are the codes that I'm receiving:
  • 0703011A12010040 [OFF]
    0703011B12010080 [DIM -]
    0703011C11010480 [Color wheel]
    0703011D11010880 [Color wheel]
    0703011E11010A00 [Color wheel]
Does anyone have an idea how to properly set-up the settings in RFXmngr for this remote ?
Probably it is a matter of identifying the proper fixed ID of the remote, but until now I have been unsuccesful.... :(
Dylantje
Post by Dylantje »
@ Bert,
This remote is supported?
nl.aliexpress.com/item/LIVOLO-Digital-W ... 44807.html
He is the brand Livolo ..
I got it, but can not get it working :cry:
mbliek
Post by mbliek »
Livolo can't be received by the RFXtrx. It can only transmit the livolo code.
nlotf
Post by nlotf »
mbliek wrote:Livolo can't be received by the RFXtrx. It can only transmit the livolo code.
My apologies for the dumb question but isn`t that the same for Byron , Home Easy or COCO units as all are one way rf switches, that you can only transmit code to them but you don`t expect a feedback ?!.. if there is something I am missing I would really appreciate if you explained it.
All the best,
b_weijenberg
Byron chime button, Home Easy and COCO remotes are received by the RFXtrx433, Livolo remotes are not received.
See also the RFXtrx User Guide.pdf chapter 2.2 which protocols are transmit only.
esschenk
Rookmelders
Post by esschenk »
