Plugwise device control is not working in v0.1.194
Moderator: RDNZL
Postby markvdm » Tue Jan 18, 2011 2:25 pm
It seems the control function for the Plugwise devices (v2.0) is not working?
I configured the device to be able to be switched off, but clicking the control button only changes the device status. The plug doesn't really switches off.
markvdm
Re: Plugwise device control is not working in v0.1.194
Postby RDNZL » Tue Jan 18, 2011 11:48 pm
Can you enable device and plugwise debug and post or e-mail debug log after switching?
Regards, Ron.
http://domotiga.nl - open source home automation software for Linux.
RDNZL
Postby wwolkers » Sat Jan 22, 2011 11:16 am
I have the same problem here. Lights are not switching anymore. not from events, not manual.
Used to work in 0.1.192
wwolkers
Postby RDNZL » Sat Jan 22, 2011 11:49 am
Just tested it, it still works here just fine in the test lab, so you guys need to come with some more info to get it fixed.
Which firmware are you running, which Plugwise settings do you have set, which log output?
Regards, Ron.
RDNZL
Postby wwolkers » Sat Jan 22, 2011 3:08 pm
Weird, one of my other plugs still works.
Probably something network related. I'll check under windows, I want to update the firmware anyways.
wwolkers
Postby wwolkers » Sun Jan 23, 2011 12:39 am
ran the plugwise updater. It cleared all the logs, updated the firmware, and now everything works like a charm again from Domotiga.
Probably related to the log on the plug being full or something?
I have a complete log of today if you want. debug is always on.
wwolkers
Postby RDNZL » Sun Jan 23, 2011 11:24 am
Thats maybe the reason it stops working without any code changes.
So how we are going to clear stuff without using the source?
You can send the log if you want maybe i can recognise this in the future.
Thanks for the info!
Regards, Ron.
RDNZL
Postby wwolkers » Sun Jan 23, 2011 12:26 pm
I mailed you yesterdays debug logfile.
Let me know if I need to test anything.
wwolkers
Return to DomotiGa Forum
Users browsing this forum: No registered users and 2 guests
