domotiga send email strange problem (upstart ?)
Moderator: RDNZL
Postby Aqua-Passion » Thu Dec 29, 2011 2:42 am
Hello
I have a strange problem with domotiga email send on ubuntu 10.04
when I start domotiga server manualy by
sudo -u username gbr2 /home/userdir/domotiga/DomotiGaServer.gambas -d
(in terminal)
I can send email with domotiga
But for boot startup I start domotiga with "upstart" on ubuntu
start the server , all is ok but email send don't work
On "send test mail" i have :
2011/12/29 01:35:35 Succesfully sent e-mail to 'xxxxx@gmail.com'.
2011/12/29 01:35:35 An error occured sending an e-mail message with subject 'DomotiGa: Test e-mail' to 'xxxxx@gmail.com'.
I have tested http://www.domotiga.nl/projects/domotig ... er-Upstart too , same problem
Domotiga logs files and systems logs files checked but just the
can you help me or give me a way please ?
thanks
Aqua-Passion
Re: domotiga send email strange problem (upstart ?)
Postby RDNZL » Thu Dec 29, 2011 12:38 pm
What does your upstart script look like exactly?
Regards, Ron.
http://domotiga.nl - open source home automation software for Linux.
RDNZL
Postby Aqua-Passion » Thu Dec 29, 2011 1:57 pm
# domotiga_server
# Serveur Domotiga
description     "DomotiGaServer Service"
author            "Ron Klinkien <info@domotiga.nl>"
start on (net-device-up
          and started mysql
          and runlevel [2345])
stop on runlevel [016]
# tell upstart we're creating a daemon
# upstart manages PID creation for you.
respawn
respawn limit 5 5
# configuratio variables
env DOMO_USER=aqua-passion
env GBX2=/usr/bin/gbx2
env GBC2=/usr/bin/gbc2
env GBC2_OPTS=-pam
# Execute the program
chdir /home/aqua-passion/domotiga/DomotiGaServer
pre-start exec sudo -H -n -u $DOMO_USER $GBC2 $GBC2_OPTS
exec sudo -H -n -u $DOMO_USER $GBX2 > /dev/null 2>&1
like from http://www.domotiga.nl/projects/domotig ... er-Upstart
tested with simply
exec sudo -u aqua-passion gbr2 /home/aqua-passion/domotiga/DomotiGaServer.gambas -d
too
both start server but mail error
when i start server with the same
in user terminal
mails send work great !
stange :-(
Aqua-Passion
Postby Aqua-Passion » Thu Dec 29, 2011 10:33 pm
I have a problem with the zwave module
so I have upgarded gamabas2 and domotiga with the next version
Mails now seems to work !
thanks
I open a new topic for the zwave problem
Aqua-Passion
Postby jrkalf » Fri Dec 30, 2011 2:00 am
aqua,
Can you confirm that the issue you had with email wasn't related to the Upstart script? It was the first version of the script for me.
Starting the domotiga server with the latest line you posted:
Will eventually lead you to issues with restarting domotiga on your ubuntu system. Or that's at least how I experienced it.
sudo will start the gbr2 process with the DomotigaServer.gambas -d project. What infact will happen is a fork of the process and the originating process will be shutdown. Therefor the Upstart system looses the PID under which it started the initial gbr2 process. This will cause the system to be unable to shutdown the DomotigaServer.gambas and therefor won't restart either.
The most correct way I've found it to be working now was the script I posted on the domotiga.nl website. If you run into any issues or have any improvements. Please let me know, it's a work in progress :mrgreen:
ELV FHT80b heating system.
jrkalf
Postby Aqua-Passion » Fri Dec 30, 2011 2:07 am
thank you very much for this script
no i have just "do a test" with
for see if it resolve mail bug
since i have updated domotiga and gambas
Server start and send mails work great with upstart :
    # domotiga_server
    # Serveur Domotiga
              and started mysql
    respawn
    respawn limit 5 5
    env GBC2_OPTS=-pam
thanks
Aqua-Passion
Return to DomotiGa Forum
Users browsing this forum: No registered users and 2 guests
