Re: Heater question
Moderator: jrkalf
Error323
Re: Heater question
Post by Error323 »
Hi everyone,
As I'm working towards a zoned heatingsystem I was looking at my heaters and tried fitting an ELV FHT8V-3. And I don't think it fits on this system. What would be the way to adapt it or what am I doing wrong here? Should I rip it further apart? I'm affraid of destroying the heater valves.
See attachments for the pictures. As they will say a 1000 words in this case.
Here are the images on imgur: http://imgur.com/a/X9bxu
Re: Re: Heater question
yes, this looks like very old!
Do you need to turn these around to get them open and closed
if Yes, then it will not work, you a version with a small pin which can be pushed down to control.
Massi
Post by Massi »
i think simply it's not a thermostatic valve..
afaik, all thermostatic valves has a "small pin" that has to be pushed or release to control valve aperture.
And MAX radiator thermostats work in that way.
Yes, you need to change the valve :)
mvdarend
Post by mvdarend »
You can get a cheap replacement (with thermostat) at your local DIY store for about 15-20 euros. (Just get a cheap one, you're not going to use the thermostat itself)
I replaced all my 'normal' taps for thermostats and it was really easy, you can probably re-use the two 'outside' fittings.
Here are the steps:
- Turn off the CV
- Find the lowest drainage point and drain the water.
- Unscrew the left fitting,
- Unscrew the right fitting
- Carefully take out the tap
- The new tap should fit in between the two original fittings, just tighten them back up on the new tap and it should be OK. Check for leaks!
mvdarend
Post by mvdarend »
hmmm, I can't edit my previous post because it's being moderated.
I forgot to add the last steps...
- Refill the system, remove any air
- And then check for leaks.
pbrand
Re: Heater question
Post by pbrand »
Keep in mind that the ELV FHT8V-3 comes with some adapter rings and some adapter rings can be purchased separately.
You might want to check/ensure that the ELV supports the thermostatic valve you buy or that you are handy enough to make it fit.
That's the main reason why I installed Danfoss thermostatic valves. Not the cheapest ones but they are supported by ELV out of the box.
Return to “Homematic, FS20, FHT, ESA and ELV”
