Powerlink serial pinout, linux daemon and web interface
Moderators: Rene, Willem4ever
ayasystems
Re: Powerlink serial pinout, linux daemon and web interface
Post by ayasystems »
Hi!
I'm in the good way...
Thanks!!
pi@raspberrypi ~/pmaxd $ make
cc  -c pmaxd.c
pmaxd.c:299:6: warning: conflicting types for 'serialHandler' [enabled by default]
pmaxd-xpl.c:44:7: note: previous implicit declaration of 'serialHandler' was here
pmaxd.c:335:6: warning: conflicting types for 'packetManager' [enabled by default]
pmaxd.c:327:9: note: previous implicit declaration of 'packetManager' was here
cc  pmaxd.o -o pmaxd -lxPL -lconfig
cc  -c xplsendjson.c
cc  xplsendjson.o -o xplsendjson.cgi -lxPL
cc  -c jsongetxplstate.c
cc  jsongetxplstate.o -o jsongetxplstate.cgi -lxPL
cc  -c testpmaxd.c
cc  testpmaxd.o -o testpmaxd -lxPL -lconfig
ayasystems
Its not working....
I've put the conf file in /etc/ after it error I/O not show
Execute pmaxd but doesn't work. The cpu is up to 98% but nothing happens
Any idea?
Regards!
ayasystems
Hi
I'm still working to do a build to raspberry.
As you can see in this link http://www.raspberrypi.org/forums/viewt ... 6&p=289490 the getopt() function works diferently in raspberry so is needed add this check to exit
while (((c = getopt (argc, argv, "fvh")) != -1) && (c != 255))
ayasystems
Now seems works....
It is needed complile with "gcc -fsigned-char" option.
pi@raspberrypi ~/pmaxd $ pmaxd[14658]: [Sat Jun 7 21:33:46 2014 initLog:0058]Logging initialized
pmaxd[14658]: [Sat Jun 7 21:33:46 2014 initLog:0059]Verbose level: 5
pmaxd[14658]: [Sat Jun 7 21:33:46 2014 main:0415]Program started by User 1000
Raspberry Pi (Debian) doesn't have service_start instruction so I don't know what code put in /etc/restart.sh
Could you help me??
ayasystems
I'm installed apache 2 on raspby.
Move www file on your source code to /var/www/
and move *.cgi to /usr/lib/cgi-bin/
wget http://localhost/cgi-bin/jsongetxplstate.cgi
restult: { "status":"","pmaxstatus":"","readytoarm":"","sensor":[]}
I think it is ready to test connected to powermax
Lunch pmaxd: (without powermax connected)
pi@raspberrypi /var/www $ pmaxd -f -vvvvv
 NOTICE: [Sat Jun  7 23:53:37 2014 initLog:0058]Logging initialized
 NOTICE: [Sat Jun  7 23:53:37 2014 initLog:0059]Verbose level: 5
 NOTICE: [Sat Jun  7 23:53:37 2014 main:0415]Program started by User 1000
 NOTICE: [Sat Jun  7 23:53:37 2014 main:0449]Starting......
I have 8 zone:
 NOTICE: [Sat Jun  7 23:53:37 2014 PmaxInit:0162]zone: 0, name: R.D.C.
 NOTICE: [Sat Jun  7 23:53:37 2014 PmaxInit:0162]zone: 1, name: Etage
 NOTICE: [Sat Jun  7 23:53:37 2014 PmaxInit:0162]zone: 2, name: Salon
 NOTICE: [Sat Jun  7 23:53:37 2014 PmaxInit:0162]zone: 3, name: Salle a manger
 NOTICE: [Sat Jun  7 23:53:37 2014 PmaxInit:0162]zone: 4, name: cuisine
 NOTICE: [Sat Jun  7 23:53:37 2014 PmaxInit:0162]zone: 5, name: porte garage
 NOTICE: [Sat Jun  7 23:53:37 2014 PmaxInit:0162]zone: 6, name: volet garage
 NOTICE: [Sat Jun  7 23:53:37 2014 PmaxInit:0162]zone: 7, name: detecteur incendie
 ERR: [Sat Jun  7 23:53:37 2014 deFormatBuffer:0203]checksum NOK calculated:00EE in packet:0000
 ERR: [Sat Jun  7 23:53:37 2014 packetManager:0359]Packet not correctly formated
 ERR: [Sat Jun  7 23:53:37 2014 logBuffer:0158]Buffer: 0B 06 00
 ERR: [Sat Jun  7 23:53:42 2014 deFormatBuffer:0203]checksum NOK calculated:00A7 in packet:00B6
 ERR: [Sat Jun  7 23:53:42 2014 packetManager:0359]Packet not correctly formated
 ERR: [Sat Jun  7 23:53:42 2014 logBuffer:0158]Buffer: 25 25 EC B6 BC 25 EC B6 00 00 00 00 A8 D5 EF B6 00 00 00 00 00 00 00 00 36 00 00 00 02 54 00 00 D9 44 DD BE 6C 45 DD BE 40 E2 E2 B6 00 05 00 00 05 00 00 00 BF 00 00 00 3B 8A 00 00 00 03 1C 7F 15 04 00 01 00 11 13 1A 00 12 0F 17 16 00 00 00 00 05 00 00 05 00 00 00 BF 00 00 00 31 8A 00 00 00 03 1C 7F 15 04 00 01 00 11 13 1A 00 12 0F 17 16 00 00 00 80 76 E9 B6 2C 45 DD BE 00 00 00 00 00 00 00 00 D4 C7 00 00 04 00 00 00 02 00 02 00 00 00 00 00 00 05 00 00 05 00 00 00 BF 00 00 00 31 8A 00 00 00 03 1C 7F 15 04 00 01 00 11 13 1A 00 12 0F 17 16 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 EC B6 0F 00 00 00 0F 00 00 00 00 05 00 00 05 00 00 0000 00
The next text will be with powermax connected.
Thank you for your work!
I'll write result with the panel connected. I'll use a ftdi USB - TLL
d0min0
Post by d0min0 »
ayasystems wrote:I'm installed apache 2 on raspby.
I have 8 zone:
I'm also connecting my Raspberry PI to my PowerMax Complete, however I am using Debian.
If you get it to work, could you do an installation guide for dummies? :-)
Thanks.
// Michael
ayasystems
I've checksum issue....
I can get it works
 NOTICE: [Tue Jun 10 00:43:25 2014 initLog:0058]Logging initialized
 NOTICE: [Tue Jun 10 00:43:25 2014 initLog:0059]Verbose level: 5
 NOTICE: [Tue Jun 10 00:43:25 2014 main:0418]Program started by User 1000
 NOTICE: [Tue Jun 10 00:43:25 2014 main:0452]Starting......
 NOTICE: [Tue Jun 10 00:43:25 2014 main:0455]initXpl....
 NOTICE: [Tue Jun 10 00:43:25 2014 main:0457]initSerialPort....
 NOTICE: [Tue Jun 10 00:43:29 2014 main:0460]PmaxInit....
 NOTICE: [Tue Jun 10 00:43:29 2014 main:0461]PASS
I have 8 zone:
 NOTICE: [Tue Jun 10 00:43:29 2014 PmaxInit:0163]zone: 0, name: R.D.C.
 NOTICE: [Tue Jun 10 00:43:29 2014 PmaxInit:0163]zone: 1, name: Etage
 NOTICE: [Tue Jun 10 00:43:29 2014 PmaxInit:0163]zone: 2, name: Salon
 NOTICE: [Tue Jun 10 00:43:29 2014 PmaxInit:0163]zone: 3, name: Salle a manger
 NOTICE: [Tue Jun 10 00:43:29 2014 PmaxInit:0163]zone: 4, name: cuisine
 NOTICE: [Tue Jun 10 00:43:29 2014 PmaxInit:0163]zone: 5, name: porte garage
 NOTICE: [Tue Jun 10 00:43:29 2014 PmaxInit:0163]zone: 6, name: volet garage
 NOTICE: [Tue Jun 10 00:43:29 2014 PmaxInit:0163]zone: 7, name: detecteur incendie
v NOTICE: [Tue Jun 10 00:43:46 2014 KeyPressHandling:0292]getting versions string
 ERR: [Tue Jun 10 00:43:46 2014 deFormatBuffer:0206]checksum NOK calculated:00F5 in packet:000D
 ERR: [Tue Jun 10 00:43:46 2014 packetManager:0362]Packet not correctly formated
 ERR: [Tue Jun 10 00:43:46 2014 logBuffer:0161]Buffer: 02 FD 0A
 ERR: [Tue Jun 10 00:43:46 2014 deFormatBuffer:0206]checksum NOK calculated:00B6 in packet:0033
 ERR: [Tue Jun 10 00:43:46 2014 logBuffer:0161]Buffer: 04 36 4A 2D 37 30 30
 ERR: [Tue Jun 10 00:43:46 2014 deFormatBuffer:0206]checksum NOK calculated:0073 in packet:0039
 ERR: [Tue Jun 10 00:43:46 2014 logBuffer:0161]Buffer: 20 76 34 2E 34 2E 31
 ERR: [Tue Jun 10 00:43:46 2014 deFormatBuffer:0206]checksum NOK calculated:00AD in packet:0076
 ERR: [Tue Jun 10 00:43:46 2014 logBuffer:0161]Buffer: 37 30 30 35 35 30 20
 ERR: [Tue Jun 10 00:43:46 2014 deFormatBuffer:0206]checksum NOK calculated:003B in packet:00FF
 ERR: [Tue Jun 10 00:43:46 2014 logBuffer:0161]Buffer: 34 2E 32 30 FF FF
 ERR: [Tue Jun 10 00:43:46 2014 deFormatBuffer:0206]checksum NOK calculated:0000 in packet:00FF
 ERR: [Tue Jun 10 00:43:46 2014 logBuffer:0161]Buffer: FF FF FF FF FF FF FF
 ERR: [Tue Jun 10 00:43:46 2014 deFormatBuffer:0206]checksum NOK calculated:00EC in packet:0071
 ERR: [Tue Jun 10 00:43:46 2014 logBuffer:0161]Buffer: FF 0A 07 08 01 F8 FF
 ERR: [Tue Jun 10 00:43:49 2014 deFormatBuffer:0206]checksum NOK calculated:007C in packet:0031
 ERR: [Tue Jun 10 00:43:49 2014 packetManager:0362]Packet not correctly formated
 ERR: [Tue Jun 10 00:43:49 2014 logBuffer:0161]Buffer: 3F 00 04 36 4A 2D 37 30 30 33 35 37 20 76 34 2E 34 2E
ayasystems
I don't know what can i do....
pi@raspberrypi ~/pmaxd $ pmaxd -vvvvvvvvvvvvvvvvvvvvvvvvvvvvv -f
 NOTICE: [Tue Jun 10 01:21:47 2014 initLog:0058]Logging initialized
 NOTICE: [Tue Jun 10 01:21:47 2014 initLog:0059]Verbose level: 29
 NOTICE: [Tue Jun 10 01:21:47 2014 main:0418]Program started by User 1000
 INFO: [Tue Jun 10 01:21:47 2014 main:0420]setting SID
 NOTICE: [Tue Jun 10 01:21:47 2014 main:0452]Starting......
 NOTICE: [Tue Jun 10 01:21:47 2014 main:0455]initXpl....
 NOTICE: [Tue Jun 10 01:21:47 2014 main:0457]initSerialPort....
 INFO: [Tue Jun 10 01:21:47 2014 initSerialPort:0071]there are 1 device in your config file
 INFO: [Tue Jun 10 01:21:47 2014 initSerialPort:0074]Intentando comunicar con
 INFO: [Tue Jun 10 01:21:52 2014 initSerialPort:0085]opening /dev/rfcomm1
 NOTICE: [Tue Jun 10 01:21:52 2014 main:0460]PmaxInit....
 NOTICE: [Tue Jun 10 01:21:52 2014 main:0461]PASS
 DEBUG: [Tue Jun 10 01:21:52 2014 logBuffer:0160]BufferSize: 180
 DEBUG: [Tue Jun 10 01:21:52 2014 logBuffer:0161]Buffer: 30 03 B5 01 02 00 01 00 04 67 00 00 00 00 00 00 08 C0 B4 01 90 93 02 00 00 00 00 00 02 00 00 00 A8 C1 B4 01 00 00 00 00 00 00 00 00 11 00 00 00 75 73 65 72 63 6F 64 65 00 00 00 00 11 00 00 00 05 00 00 00 50 03 B5 01 00 00 00 00 49 00 00 00 00 03 B5 01 98 03 B5 01 20 04 B5 01 60 07 B5 01 C0 07 B5 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 31 00 00 00 C8 03 B5 01 07 00 00 00 08 04 B5 01 00 00 00 00 08 C0 B4 01 90 93 02 00 00 00 00 00
I have 8 zone:
 NOTICE: [Tue Jun 10 01:21:52 2014 PmaxInit:0163]zone: 0, name: R.D.C.
 NOTICE: [Tue Jun 10 01:21:52 2014 PmaxInit:0163]zone: 1, name: Etage
 NOTICE: [Tue Jun 10 01:21:52 2014 PmaxInit:0163]zone: 2, name: Salon
 NOTICE: [Tue Jun 10 01:21:52 2014 PmaxInit:0163]zone: 3, name: Salle a manger
 NOTICE: [Tue Jun 10 01:21:52 2014 PmaxInit:0163]zone: 4, name: cuisine
 NOTICE: [Tue Jun 10 01:21:52 2014 PmaxInit:0163]zone: 5, name: porte garage
 NOTICE: [Tue Jun 10 01:21:52 2014 PmaxInit:0163]zone: 6, name: volet garage
 NOTICE: [Tue Jun 10 01:21:52 2014 PmaxInit:0163]zone: 7, name: detecteur incendie
 DEBUG: [Tue Jun 10 01:21:52 2014 sendBuffer:0177]Sending the following buffer to serial TTY
 DEBUG: [Tue Jun 10 01:21:52 2014 logBuffer:0160]BufferSize: 12
 DEBUG: [Tue Jun 10 01:21:52 2014 logBuffer:0161]Buffer: A2 00 00 00 00 00 00 00 00 00 00 43
 DEBUG: [Tue Jun 10 01:21:52 2014 calculChecksum:0170]checksum: 001A
 DEBUG: [Tue Jun 10 01:21:52 2014 sendBuffer:0186]result of serial write:: 15
 DEBUG: [Tue Jun 10 01:21:52 2014 logBuffer:0161]Buffer: AB 06 00 00 00 00 00 00 00 00 00 43
 DEBUG: [Tue Jun 10 01:21:52 2014 calculChecksum:0170]checksum: 000B
 DEBUG: [Tue Jun 10 01:21:52 2014 main:0464]Sarting main loop....
 DEBUG: [Tue Jun 10 01:21:52 2014 packetManager:0342]Timeout while waiting packet: assumig packet is complete......
 DEBUG: [Tue Jun 10 01:21:52 2014 calculChecksum:0170]checksum: 0000
 ERR: [Tue Jun 10 01:21:52 2014 deFormatBuffer:0206]checksum NOK calculated:0000 in packet:000A
 ERR: [Tue Jun 10 01:21:52 2014 packetManager:0362]Packet not correctly formated
 DEBUG: [Tue Jun 10 01:21:52 2014 logBuffer:0160]BufferSize: 3
 ERR: [Tue Jun 10 01:21:52 2014 logBuffer:0161]Buffer: 02 43 BA
 DEBUG: [Tue Jun 10 01:21:52 2014 packetManager:0369]End of packet treatment
 DEBUG: [Tue Jun 10 01:21:53 2014 packetManager:0342]Timeout while waiting packet: assumig packet is complete......
 DEBUG: [Tue Jun 10 01:21:53 2014 calculChecksum:0170]checksum: 0084
 ERR: [Tue Jun 10 01:21:53 2014 deFormatBuffer:0206]checksum NOK calculated:0084 in packet:000D
 ERR: [Tue Jun 10 01:21:53 2014 packetManager:0362]Packet not correctly formated
 DEBUG: [Tue Jun 10 01:21:53 2014 logBuffer:0160]BufferSize: 31
 ERR: [Tue Jun 10 01:21:53 2014 logBuffer:0161]Buffer: 09 01 00 00 00 00 00 00 00 00 43 0D 0A 0D 02 43 BA 0A 0D A5 09 01 00 00 00 00 00 00 00 00 43
 DEBUG: [Tue Jun 10 01:21:53 2014 packetManager:0369]End of packet treatment
t NOTICE: [Tue Jun 10 01:21:56 2014 KeyPressHandling:0288]try re-enroll
 DEBUG: [Tue Jun 10 01:21:56 2014 sendBuffer:0177]Sending the following buffer to serial TTY
 DEBUG: [Tue Jun 10 01:21:56 2014 logBuffer:0160]BufferSize: 12
 DEBUG: [Tue Jun 10 01:21:56 2014 logBuffer:0161]Buffer: AB 06 00 00 00 00 00 00 00 00 00 43
 DEBUG: [Tue Jun 10 01:21:56 2014 calculChecksum:0170]checksum: 000B
 DEBUG: [Tue Jun 10 01:21:56 2014 sendBuffer:0186]result of serial write:: 15
 DEBUG: [Tue Jun 10 01:21:56 2014 packetManager:0342]Timeout while waiting packet: assumig packet is complete......
 DEBUG: [Tue Jun 10 01:21:56 2014 calculChecksum:0170]checksum: 0053
 ERR: [Tue Jun 10 01:21:56 2014 deFormatBuffer:0206]checksum NOK calculated:0053 in packet:0000
 ERR: [Tue Jun 10 01:21:56 2014 packetManager:0362]Packet not correctly formated
 DEBUG: [Tue Jun 10 01:21:56 2014 logBuffer:0160]BufferSize: 254
 ERR: [Tue Jun 10 01:21:56 2014 logBuffer:0161]Buffer: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 36 00 00 00 02 54 00 00 B9 94 E8 BE 4C 95 E8 BE 40 E2 E7 B6 00 05 00 00 05 00 00 00 BF 00 00 00 3B 8A 00 00 00 03 1C 7F 15 04 00 01 00 11 13 1A 00 12 0F 17 16 00 00 00 00 05 00 00 05 00 00 00 BF 00 00 00 31 8A 00 00 00 03 1C 7F 15 04 00 01 00 11 13 1A 00 12 0F 17 16 00 00 00 80 76 EE B6 0C 95 E8 BE 00 00 00 00 00 00 00 00 00 C8 00 00 04 00 00 00 02 00 02 00 00 00 00 00 00 05 00 00 05 00 00 00 BF 00 00 00 31 8A 00 00 00 03 1C 7F 15 04 00 01 00 11 13 1A 00 12 0F 17 16 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 F1 B6 0F 00 00 00 0F 00 00 00 00 05 00 00 05 00 00 00 BF 00 00 00 3B 8A 00 00 00 03 100 00
 DEBUG: [Tue Jun 10 01:21:56 2014 packetManager:0369]End of packet treatment
 DEBUG: [Tue Jun 10 01:21:56 2014 calculChecksum:0170]checksum: 00F5
 ERR: [Tue Jun 10 01:21:56 2014 deFormatBuffer:0206]checksum NOK calculated:00F5 in packet:0000
 DEBUG: [Tue Jun 10 01:21:56 2014 logBuffer:0160]BufferSize: 7
 ERR: [Tue Jun 10 01:21:56 2014 logBuffer:0161]Buffer: 09 01 00 00 00 00 00
 DEBUG: [Tue Jun 10 01:21:56 2014 calculChecksum:0170]checksum: 00D1
 ERR: [Tue Jun 10 01:21:56 2014 deFormatBuffer:0206]checksum NOK calculated:00D1 in packet:0000
 DEBUG: [Tue Jun 10 01:21:56 2014 logBuffer:0160]BufferSize: 13
 ERR: [Tue Jun 10 01:21:56 2014 logBuffer:0161]Buffer: 43 0D 0A 0D 02 43 BA 0A 0D A5 09 01 00
 DEBUG: [Tue Jun 10 01:21:56 2014 calculChecksum:0170]checksum: 00BC
 ERR: [Tue Jun 10 01:21:56 2014 deFormatBuffer:0206]checksum NOK calculated:00BC in packet:000D
 DEBUG: [Tue Jun 10 01:21:56 2014 logBuffer:0160]BufferSize: 5
 ERR: [Tue Jun 10 01:21:56 2014 logBuffer:0161]Buffer: 00 00 00 00 43
Please any help!
Best regards
viknet
Post by viknet »
definitely a problem with timeout, try changing it, otherwise it is a pretty good start
ayasystems
It is working finally thanks to viknet !!!
Raspberry need higher timeout value
It is the make file with the correct options to compile pmaxd sources into raspbian
I'm ussing apache2 to publish web
Note: you can execute make install to copy compiled files.
# build helloworld executable when user executes "make"
CFLAGS          += -I $(SRCDIR)/FLU $(OPTIMIZE) $(DEBUG) -fsigned-char
LDFLAGS         += -fsigned-char
CC              = $(CROSS_COMPILE)gcc
all: pmaxd xplsendjson jsongetxplstate testpmaxd
install: pmaxd xplsendjson jsongetxplstate testpmaxd
	cp -f pmaxd /usr/bin/pmaxd
	cp -f testpmaxd /usr/testpmaxd
	cp -f xplsendjson.cgi /usr/lib/cgi-bin/xplsendjson.cgi
	cp -f jsongetxplstate.cgi /usr/lib/cgi-bin/jsongetxplstate.cgi
pmaxd: pmaxd.o
	$(CC) $(LDFLAGS) pmaxd.o -o pmaxd -lxPL -lconfig
pmaxd.o: pmaxd.c
	$(CC) $(CFLAGS) -c pmaxd.c
xplsendjson: xplsendjson.o
	$(CC) $(LDFLAGS) xplsendjson.o -o xplsendjson.cgi -lxPL
xplsendjson.o: xplsendjson.c
	$(CC) $(CFLAGS) -c xplsendjson.c
jsongetxplstate: jsongetxplstate.o
	$(CC) $(LDFLAGS) jsongetxplstate.o -o jsongetxplstate.cgi -lxPL
jsongetxplstate.o: jsongetxplstate.c
	$(CC) $(CFLAGS) -c jsongetxplstate.c
testpmaxd: testpmaxd.o
	$(CC) $(LDFLAGS) testpmaxd.o -o testpmaxd -lxPL -lconfig
testpmaxd.o: testpmaxd.c
	$(CC) $(CFLAGS) -c testpmaxd.c
# remove object files and executable when user executes "make clean"
clean:
	rm *.o pmaxd testpmaxd xplsendjson.cgi jsongetxplstate.cgi
ayasystems
Finally mount wr702N
It's working fine!
2014-06-20 20.17.12.jpg (289.03 KiB) Viewed 20186 times
2014-06-20 20.16.46.jpg (197.25 KiB) Viewed 20186 times
bartbakels
Post by bartbakels »
Great work all,
Im quite interested in a prebuild image for a raspberry to interface the visonic, which can be readout by HS3. Probably via the custom webinterface u guess created by Get and Put commands.
regards
Bart
(ON ESXI )on NUC
ayasystems
bartbakels wrote:Hi,
Great work all,
regards
Bart
Hi Bartbakels,
I can compile viknet code to raspberry but it is not working fine. It is having problems with serial link. I don't have enough knowledge to modify it.
To compilte it to raspberry only is needed a correct makefile file. Raspberry don't understan char unsigned and it must be specified in the makefile file.
Could you adapt viknet serial code to works in rapsberry?
In the actual state in raspberry is not funcional.
Best regards!
bartbakels
sorry, the reason that I asked for an image, is that my linux knowledge is very high level ;). Maybe someone else can help. I Know Phaeton is also still looking for an possibility to interface the visonic in HS3. I also started a thread, to recreate an HS3 plugin in the Visonic plugin setion, but no much animo i guess...
regards
Bart
(ON ESXI )on NUC
viknet
Post by viknet »
ayasystems, I don't really understand where you are connected on the powermax, aren't you using the PC/IP port ?
