Solution to monitor water/gas/electricity?
DJF3
Post by DJF3 »
What's currently the best Solution to monitor water/gas/electricity?
Would like to integrate with HS3.
DJ
123unlock
Re: Solution to monitor water/gas/electricity?
Post by 123unlock »
what I use here:
Water > RFXCOM
Gas / Power > Smart meter P1 port
Xtrusion Digital Home Automation Project
Mai Pensato
Post by Mai Pensato »
@123unlock:
Can you describe your solution with your watermeter and RFXcom ? I also try to monitor my water usage via RFXmeter+RFXpulse and RFXcom. But it does not yet work 100% reliable. See also my recent reply in the RFXcom topic
Akatar
Post by Akatar »
i just asked for the watercompagny for a meter with a output for a external counter
and they did installed one
Mai Pensato
What meter did they install and which external counter do you use?
Akatar
Post by Akatar »
they installed a meter with s0 output, i connected a rfxcom pluse counter
123unlock
Post by 123unlock »
I use it with the reflective sensor, there is a little spinning wheel that turns around one time per liter
took some time to carefully calibrate the reflective sensor, but last year my rfxmeter was only 12 liters off with the main meter
on yearly base I think this is acceptable :)
Mai Pensato
@123unlock: I have exactly the same solution! At this moment I have a bigger deviation: approximately 1% too high, which is more like 10-12 liters per week. How did you calibrate the sensor ? I used the potentiometers P1 and P2 on the RFXpulse. Did you also use the jumpers JP3 and JP4 to set the debounce time ? If yes what is your setting? I have now both jumpers open = debounce time 65ms
raymonvdm
Post by raymonvdm »
Akatar wrote:they installed a meter with s0 output, i connected a rfxcom pluse counter
Vitens? And if so what brand of meter did they replace the old meter with?
Akatar
Post by Akatar »
deze, komen minimaal 4/5 draden uit
is op diverse manieren uit te lezen
ik zit in groningen, zal geen vitens zijn?
raymonvdm
Post by raymonvdm »
Ik denk dat https://waterbedrijfgroningen.nl/ daar de levering doet :-)
Mai Pensato
Mai Pensato wrote:@123unlock: I have exactly the same solution! At this moment I have a bigger deviation: approximately 1% too high, which is more like 10-12 liters per week. How did you calibrate the sensor ? I used the potentiometers P1 and P2 on the RFXpulse. Did you also use the jumpers JP3 and JP4 to set the debounce time ? If yes what is your setting? I have now both jumpers open = debounce time 65ms
Anyone experieces or tips you want to share to get the measurements as reliable as possible ??
