The first version of the Plugin will support 1 RF-Module and 4 Controllers (locks). I think that will be enough for most
You can read more about the hardware here: viewtopic.php?f=23&t=4775&start=0
Here's a list of the features the Plugin will have:
- Badge Management: Assign names to Badges (to keep record of to whom Badges are handed out to) and registering the Badge type;
- Unlock the Nemef Radaris Evolution (duh);
- Control the 4 outputs of the RF Module;
- Monitoring the 3 inputs on the RF Module;
- Switch Conditional Access on and off per Controller;
- Configure the Unlock time of each Controller;
- Monitor the battery condition of the Controller(s);
- Monitor the bolt position (In, Out) of the Controller(s);
- Configure the access granted for each Badge per Controller (inside, outside, none, conditional)
- Connection to Homeseer either by RS232 or Ethernet;
- Fully integrated in Homeseer; 'everything' is exposed to Homeseer and can therefore be used in Homeseer events and scripts.
And here some screendumps:
