HS2 vs Fibaro MultiSensor FGMS-001 V2.6
Forum all about Z-Wave Fibaro
xanhoera
Post by xanhoera »
Next on my list is trying to include the Fibaro MultiSensor FGMS-001 V2.6 in HomeSeer 2. I can't seem to let HS2 add the (child)device for the temperature sensor. Other child devices (battery, luminance, motion sensor) are added. Anyone has a positive experience adding this device to HS2? The device shows up regularly as a problem device, probably because it doesn't seem to be officially z-wave certified :-(.
Thanks!
raymonvdm
Re: HS2 vs Fibaro MultiSensor FGMS-001 V2.6
Post by raymonvdm »
Did you test it under HS3 (30 day trial?)
I have a Danfoss LC13 which has the same issue under both HS2 and HS3
Return to “Fibaro”
