Toon App: DoorCam
- Advanced Member
Re: Toon App: DoorCam
Nog even wachten op de laatste goedkeuing, er komt weer een nieuwe versie aan (zat nog een klein foutje in). Jouw verzoek is ook gelijk meegenomen in 1.3.3
- Member
Installed the new version. Happy that the tile now only displays the word ‘Doorcam’. Great! Thanks!
Heyy, one little question...
Is the start post info still relevant?
Because when I look at github there's only mentioned to create "ShowDoorCamToon" and a value, but the timer etc in blocky isn't noticed at all.
Thanks for creating the app
- Advanced Member
Got a little bit confused.. What information on Github?
This info:
https://github.com/oepi-loepi/doorcam/b ... ngelog.txt
But managed to get it working with Domoticz and Toon but using dzVents script from here:
https://www.domoticz.com/forum/viewtopi ... 91#p231191
Thanks for reply that quick
- Advanced Member
aha, didn't remember i added that in the changelog.. Good that it works now.
@oepi-loepi, I think there is a typo somewhere, 1.3.4 won't install. The log shows:
19/02/2023 19:25:54 Installing: doorcam-1.3.4
19/02/2023 19:25:54 Can not find doorcam 1.3.4 in github!
- Advanced Member
solved
Works, thnx! Awesome app!
And as a feature request: you've created the option to upload the HA-token in the userSettings. Perhaps a button to use/import the key from the HA-controller app would be benificial? This would reduce the need to save the token on 2 locations.
When used it is located in /mnt/data/tsc/homeassistant.token.txt.
- Advanced Member
ok, good advice. Let me think about that..
Hi, I have purchased the Reolink doorbell and configured the app as described in the opening post. When I open the doorcam app for the first time after rebooting Toon, the doorcam image is displayed. However, when I close the app and open it again it shows: No Connection To Camera
I have configured this URL (as described here):
I configured the HTTP stream because the HTTPS stream doesn't work at all (it does in the browser)
I have no problems with opening the HTTP steam with my browser. Also, when I press F5 the page reloads without any problems
(The connection to my Home Assistant works. The doorcam app opens when I change the value of the helper to 200 and closes when I change the value to 100)
EDIT: When I restart the GUI (killall qt-gui), the doorcam works again (for once). For now, I'm running a script that executes the SSH command 5 minutes after the bell rings.
http://192.168.xxx.xxx/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=USERNAME&password=PASSWORD
- Advanced Member
Looks like the timer to refresh the image is to fast. I have seen it before. Can hou slow the timer?
Doorcamfullscreen line 21
You can slow down the timer by increasing the number, right? I tried both (increasing and decreasing) but no luck. I also changed the number in line 19 because I am using cgiMode, but no luck either.
Should the green bar at the bottom of the screen count down? Because the bar stays at 100% all the time.
EDIT: Ok, it's working now. I changed the setting from cgiMode to JPG mode and now it works.
I thought JPG mode didn't work, but I think I was still testing with HTTPS earlier.
- Member
Since a couple of weeks, after my doorbell is pressed, my Toon thermostat resets.
Not always, sometimes I see the camera image, but very frequently I see the reset screen instead of the camera image.
Any idea what causes this?
- Advanced Member
It shouldn’t and nothing is changed in the software. Maybe it is a memory problem or shortage when getting the images. Coul d you do a hard reset by a full restart? Power cycle your toon.
