Eaton stops XanuraHome production?
Postby TANE » Wed Jul 01, 2009 11:20 pm
There is good support for zwave in Homeseer when using the supported PC interface.
Merten, Homepro, popp and all the other zwave modules are compatible with any other zwave module.
Postby Fantic » Wed Jul 01, 2009 11:24 pm
Enver thanks, that is what I was hoping for.
@digit: this requires additional wiring, correct? This is just what I was trying to prevent by choosing Xanura, the variety in modules available is also what attracted me.
Regards, Maarten.
Fantic
Postby Digit » Wed Jul 01, 2009 11:46 pm
From what i know (i'm no Xanura expert, i only have 2 SAIX and a IMX) not different from Xanura. Most modules need L and N. So if you were planning Xanura that shouldn't be a problem. All modules can send ACK on a command. Disadvantage is that they don't transmit local changes, so you need to poll for that.
And try to use the best of all available worlds :-)
Postby Peterpc » Thu Jul 02, 2009 7:37 am
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by fantic</i>
<br />
Is there any other system supporting the same functionality? (Marmitek without status check is not a real alternative)
Regards, Maarten.
The Marmitek TM13, LWM1, AWM2, SWM1P, TWM4, AWM2P, all support status request and extended commands!
Peterpc
Postby MindBender » Thu Jul 02, 2009 10:51 am
I can confirm that: Marmitek modules offer the exact same functionality as their Xanura counter parts. Some Xanura features are not specified in the Marmitek documentation, but they are present and functional. Check this thread too:
topic.asp?TOPIC_ID=33
MindBender
Postby Alexander » Thu Jul 02, 2009 1:34 pm
Just curious: Has marmitek used the techn. from xanura? Its like marmitek has bought a license from xanura.
Alexander
Postby blackbird » Thu Jul 02, 2009 4:33 pm
As I was planning to update my new house to Xanura, this whole tread makes me think twice about buying a complete Xanura installation. Now my attention shifted a bit towards <b>KNX/EIB Powernet</b>. Does anyone of you have any experience with this system? As far as I can see, it combines a main advantage of KNX (future proof) with the big advantage of X10/A10 (small modules, data over 230V). Maybe this is a new option for me.
blackbird
Postby Alexander » Thu Jul 02, 2009 4:39 pm
KNX needs an additional wire, correct?
Alexander
Postby Lempens » Thu Jul 02, 2009 11:31 pm
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MindBender</i>
<br />I can confirm that: Marmitek modules offer the exact same functionality as their Xanura counter parts. Some Xanura features are not specified in the Marmitek documentation, but they are present and functional. Check this thread too:
That's not completely true, when you press several times in a few seconds the button from a Marmitek dimmer, it goes into it's program mode. The only way to abort is to disconnect the power. Xanura doesn't have this problem, because the have a small program button.
Lempens
Postby Peterpc » Fri Jul 03, 2009 9:27 am
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Lempens</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MindBender</i>
LWM1, AWM2, SWM1P, TWM4, AWM2P have a program button.
Peterpc
Postby Lempens » Fri Jul 03, 2009 9:49 am
Sorry, not al moduels from Marmitke have this problem.
Lempens
Postby Bwired » Fri Jul 03, 2009 10:03 am
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mgizmo</i>
<br />Just curious: Has marmitek used the techn. from xanura? Its like marmitek has bought a license from xanura.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">That's right a long time ago, I guess a lot of Marmitek modules are still on the same version while Xanura moved on developing.
I'm not sure about the new Marmitek modules.
Postby blackbird » Fri Jul 03, 2009 7:43 pm
<br />KNX needs an additional wire, correct?
KNX Powernet works the same like X10/A10 in a way that Powernet transmits data over 230V and needs no extra wires besides the normal LNE wirering everyone uses for the power outlets.
blackbird
Postby Merdeka » Thu Jul 09, 2009 10:26 pm
KNX/EIB Powernet indeed uses the power lines for communication. The problem is that there is only hardware available from two suppliers. Busch Jaeger being one of them.
I have a KNX/EIB system in our house. It's a wired system that uses the green 2pair EIB cable. This type of cable is a bit thick so wiring can be a challenge in existing houses.
Most of my hardware I bought on ebay.de but it's still is a bit on the expensive side if you ask me. Especially dimmers.
If you know what you are doing and plan ahead it can be a DIY job. The biggest challenge for me was getting ETS3 which you need to program the system.
Misterhouse has support for EIB and I'm working on support for DomotiGa. I have switching and dimming working here atm.
Merdeka
Postby Bwired » Mon Aug 31, 2009 3:29 pm
Zie hier
topic.asp?TOPIC_ID=3387
PreviousNext
Return to X10, A10 Xanura Marmitek Forum
