Wireless door/window sensor
Moderator: b_weijenberg
Postby Kroonen » Sun Oct 28, 2007 8:58 pm
Will this sensor workd with the rfxcom?? It's not expensive so.
http://www.klikaanklikuit.nl/product_detail.asp?id=46
regards Richard
Kroonen
Postby b_weijenberg » Sun Oct 28, 2007 9:05 pm
No, that type of sensors are not received.
see topic.asp?TOPIC_ID=502
b_weijenberg
Postby Bwired » Sun Oct 28, 2007 9:26 pm
Take Visonic, those sensors have a double function
Door windows sensors, smoke detectors and pirs etc can be received by Rfxcom and also work for your alarm system!
They are a bit more expensive but have a very high quality!
Regards Pieter
Postby ross » Tue Nov 13, 2007 11:39 pm
i found on the internet two types of rfxcom 4xx mhz and 8xx mhz.
do you need 2 if you want sd90 smoke detector and the Visonic door thing.
ross
Postby Snelvuur » Tue Nov 13, 2007 11:50 pm
you need 2 receivers (one for normal things, like the sd90. The other for visonic) the mhz apply's also where you live. Dont know where that is.
Snelvuur
Postby b_weijenberg » Wed Nov 14, 2007 12:00 am
For X10 the European freq is 433.92MHz while for the US this is 310MHz.
For Visonic both frequencies 433.92 and 868.95 are used in Europe. In NL mainly 868.95MHz is used.
In the US Visonic uses 315MHz.
If you want to receive both, X10 and Visonic in NL select an USB or Ethernet interface with a 433.92MHz X10 receiver:
http://www.rfxcom.com/receivers.htm#70003
And add a 868.95MHz Visonic receiver:
http://www.rfxcom.com/receivers.htm#40079
b_weijenberg
Postby ross » Wed Nov 14, 2007 12:44 am
thx for the repl
i don't get the " you must ADD " part ????
solder something
ross
Postby b_weijenberg » Wed Nov 14, 2007 10:52 am
In this case ADD means add to your shopping list.
The receivers and the interfaces have a connector and it is Plug&Play.
b_weijenberg
Postby Gourmet » Fri Nov 23, 2007 1:36 pm
You can also use a modified MS13 for that. The MS13 uses 2 X10 addresses, one for motion detection (PIR) and another one for dust/dark detection.
You can then replace the varistance by something else (a reed relay, a pulse counter, etc) and everytime the resistance of the new circuit falls below some value the MS13 will transmit an ON on the second address (A1+1). On the opposite way each time the resistance gets above another value you'll have an OFF.
This way, you'll have nearly a free new sensor!
db
db
Gourmet
Return to Rfxcom Receivers & Transmitters Forum
Users browsing this forum: No registered users and 2 guests
