trouble in reading out oregon uv138 sensor *SOLVED
Moderator: b_weijenberg
Postby docbee » Sat Jul 07, 2007 10:23 am
hi,
i do have problems in getting the checksum right with the sensor data on my uv138 sensor.
the incoming data is:
0. 78 (record length in bits = 15 bytes)
1. ea (sensor id, high byte)
2. 7c (sensor id, low byte)
3. 10
4. 80
5. 30
6. 40
7. fe (high nibble is checksumw2 = f)
8. 43 (low nibble is checksumw1 = 3)
9. fd
10. ff
11. af
12. ce
13. 07
14. 01
15. 08
according to the documentation the checksum should be 3f.
but when i sum up the bytes 1-6 i get 3b - 0a = 31. hmmm, where is my mistake?
docbee
Postby Bwired » Sat Jul 07, 2007 11:46 am
Hi
Did you check the source code (vb.net)
this is the checksum check for the UV sensor
Hope this helps a bit!
Sub checksum7()
Dim cs As Byte
cs = (recbuf(0) >> 4 And &HF) + (recbuf(0) And &HF)
cs += (recbuf(1) >> 4 And &HF) + (recbuf(1) And &HF)
cs += (recbuf(2) >> 4 And &HF) + (recbuf(2) And &HF)
cs += (recbuf(3) >> 4 And &HF) + (recbuf(3) And &HF)
cs += (recbuf(4) >> 4 And &HF) + (recbuf(4) And &HF)
cs += (recbuf(5) >> 4 And &HF) + (recbuf(5) And &HF)
cs += (recbuf(6) >> 4 And &HF) + (recbuf(6) And &HF)
cs -= recbuf(7)
cs -= &HA
If cs <> 0 Then
WriteMessage(" Checksum Error", False)
End If
End Sub
Postby b_weijenberg » Sat Jul 07, 2007 12:43 pm
You have to add half bytes as in the function checksum7, subtract byte 7 and subtract 0x0A.
I have checked your in the RFreceiver with simulate and the data has a correct checksum:
Simulate: 78ea7c10803040fe43fdffafce070108
UV138 UV sensor CH 1 addr:80 UV factor:3 Level: medium bits=120
bert
b_weijenberg
Postby docbee » Sat Jul 07, 2007 2:09 pm
inpecting the rfreceiver source code did help. uv138 is checksummed by the following code:
Function checksumw() As Byte
        Dim cs As Byte
        cs += (recbuf(6) And &HF)
        cs -= (recbuf(6) >> 4 And &HF) + (recbuf(7) << 4 And &HF0)
        cs -= &HA
        If cs <> 0 Then
        End If
        Return cs
    End Function
unfortunately this does not match the pdf documentation. they forgot to put in the lower nibble of byte 6. Here is the text from the documentation:
checksumw1, checksumw2
This is an 8 bits checksum and is calculated by adding all the nibbles of the bytes 0 to 5 minus (checksumw1 * hex 10 + checksumw2) minus hex A.
Thanks for getting this one solved!
docbee
Postby Bwired » Sat Jul 07, 2007 2:40 pm
OK that's great, The documentation will be corrected thats for sure!
Postby b_weijenberg » Sat Jul 07, 2007 2:42 pm
You are right, the doc has been changed to:
This is an 8 bits checksum and is calculated by adding all the nibbles of the bytes 0 to 5, plus the lower nibble of byte 6, minus (checksumw1 * hex 10 + checksumw2) minus hex A.
b_weijenberg
Postby docbee » Sat Jul 07, 2007 4:54 pm
HI,
i just had a look at the error log of my sw. beside other things i get information about records that cannot be decoded so far. there i found the following entries:
wmr928d: unidentified byte sequence: 44 ea 7c 10 80 40 90 4d 14 14
wmr928d: unidentified byte sequence: 44 ea 7c 10 80 90 d0 aa 94 12
wmr928d: unidentified byte sequence: 44 ea 7c 10 80 50 40 0d 84 12
wmr928d: unidentified byte sequence: 44 ea 7c 10 80 30 50 0e 44 1a
wmr928d: unidentified byte sequence: 44 ea 7c 10 80 20 80 2e d4 1c
wmr928d: unidentified byte sequence: 44 ea 7c 10 80 40 b0 6d 14 1a
wmr928d: unidentified byte sequence: 44 ea 7c 10 80 20 a0 4e d4 12
looks like data from the uv138 sensor, but the record length (44) doesn't match to the specified 40/78 record lengths in the documentation. however, i will give decoding these signals a try. stay tuned ;-)
what makes me wonder is that the uv138 seems to send out data in two different formats. may be they do that in order to be compatible to older weather stations? just guessing...
docbee
Postby Bwired » Sat Jul 07, 2007 5:13 pm
Hi Docbee,
Let us know what you find out. Don't be surprised that you receive sensors from people in the neighborhood. b_weijenberg (Bert) told his neighbor that is was time to replace the battery of his Oregon Temperature sensor [:D]
I'm receiving also all the Visonic sensors in the neighborhood.
Question: Where did you place the UV sensor, I think it needs to be outside, but the UV138 does not look that weatherproof to me.
Regards Pieter
Postby b_weijenberg » Sat Jul 07, 2007 6:24 pm
You can ignore the bytes above 64.
The 1st 64 bits contain a valid UV138 packet.
Simulate: 40ea7c108020a04ed4
UV138 UV sensor CH 1 addr:80 UV factor:2 Level: low bits=64
I don't know why but sometimes the sensors transmit additional random data. Don't check the packet length. I think you can check the first 2 bytes (sensor ID) and if the checksum is OK process the packet.
Bert
<font size="1">(I found an error in the RFreceiver program, packets with a length not on an 8 bits boundary are not accepted as valid. I will correct this soon.)</font id="size1">
b_weijenberg
Postby docbee » Sat Jul 07, 2007 7:30 pm
@bwired: the uv138 got some serious rain during the last two days. it is still working... we 'll see ;-)
when doing my first tests with the rfreceiver i got a temperature signal that looks like from outside (based on the value) but was not part of my wmr928 rig. looking around the house i found a sensor from an old weather station (bought 2 years ago from aldi or so) still hanging in my car port. looks like beeing an oregon clone although it has been labled as "lifetec". however, i now use this sensor to monitor my wine cooling ;-) of course, it sends a lowbat in the meantime ;-)
docbee
Postby b_weijenberg » Sun Jul 08, 2007 12:08 am
I think I have to check your wine to see if the sensor did his job OK!
b_weijenberg
Postby Bwired » Sun Jul 08, 2007 12:19 am
Yes Bert, your story that I told above is again reality [8D]
Return to Rfxcom Receivers & Transmitters Forum
