I hope this is the right topic, please move this topic if it isn't correct (otherwise I have to type it all over again).
In my new house I want to install 3 sets of led spots. I want my spots to be able to dim but I can´t figure out which to choose.
Option 1.
Use 230V spots using GU10 fitting. Z-wave Dimmer to controll the lights
pros: cheap lightning fitting. Easy to install.
cons: expensive leds, using 10 cm of height to install, lights can flicker on lowest lever dimmer ??
Option 2.
Use 12V spots using MR16 fitting. X10 pulse switch dimmer.
pros: cheap(er), less installation height
cons: x10... more work to install, powerline noise, device limitations, one way communication. My electronics friend told me 12V wil be phased out soon.
I won't ask you which one will be the best.. but what I like to know is..
Option 2 seems a better option for me. It will cost me about 30 euro per spot. The dimmer + trafo are a bit more expensive and I have no clue which product I do have to order.
Besides, I definetely want to see the difference between these LEDs vs Halogen lights. Are there any pulse switches using z-wave or another protocol?
I want these lights to be able to configure them by RC, Touchscreen or Phone App. so the reading the status is very appreciated..
Am I making the right choise?
Thanks, Gr. Martijn.
Lightplan for Led spots
Moderator: Mversluis
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
