Hi Digit,
I guess it was indeed truncated. I did copy it from wireshark which is not that easy with long messages. I have now copied the output after I initiate the telnet session:
- Code: Select all
01 H:IEQ0112015,00bbfa,0102,00000000,45f5c6f1,25,32
02 M:00,01,VgICAQhCYWRrYW1lcgA6FwIPWm9sZGVyIG92ZXJsb29wADXdAgEAOhdJRVEwMTA5NjE4CEJhZGthbWVyAQEANd1JRVEwMTA4ODM2D1pvbGRlciBvdmVybG9vcAIB
03 C:00bbfa,7QC7+gACAf9JRVEwMTEyMDE1AAsABEAAAAAAAAAAAP///////////////////////////wsABEAAAAAAAAAAQf///////////////////////////2h0dHA6Ly93d3cubWF4LXBvcnRhbC5lbHYuZGU6ODAvY3ViZQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==
04 C:003a17,0gA6FwEBFP9JRVEwMTA5NjE4Kh49CQcYAzAD/wBAVFSRSORU/kEgQSBBIEUgRSBFIEUgRSBFIEBUVJFI5FT+QSBBIEEgRSBFIEUgRSBFIEUgQEhWbETkVRRBIEEgQSBFIEUgRSBFIEUgRSBASFRsRORVFEEgQSBBIEUgRSBFIEUgRSBFIEBIVGxE5FUUQSBBIEEgRSBFIEUgRSBFIEUgQEhUbETkVRRBIEEgQSBFIEUgRSBFIEUgRSBASFRsRORVFEEgQSBBIEUgRSBFIEUgRSBFIA==
05 C:0035dd,0gA13QECFP9JRVEwMTA4ODM2Kh49CQcYAzAM/wBESEUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIRQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhFCEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESEUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIRQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhFCEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESEUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
06 L:CwA6FwASGgAKgYsACwA13QASGgAKgYsA
02 HEX 56020201084261646B616D6572003A17020F5A6F6C646572206F7665726C6F6F700035DD0201003A1749455130313039363138084261646B616D657201010035DD494551303130383833360F5A6F6C646572206F7665726C6F6F700201
02 ASC V[2][2][1][8]Badkamer[0]:[23][2][15]Zolder overloop[0]5[221][2][1][0]:[23]IEQ0109618[8]Badkamer[1][1][0]5[221]IEQ0108836[15]Zolder overloop[2][1]
03 HEX ED00BBFA000201FF49455130313132303135000B0004400000000000000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B0004400000000000000041FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF687474703A2F2F7777772E6D61782D706F7274616C2E656C762E64653A38302F6375626500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000043455400000A000300000E10434553540003000200001C20
03 ASC [237][0][187][250][0][2][1][255]IEQ0112015[0][11][0][4]@[0][0][0][0][0][0][0][0][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][11][0][4]@[0][0][0][0][0][0][0]A[255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255][255]http://www.max-portal.elv.de:80/cube[0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0][0]CET[0][0][10][0][3][0][0][14][16]CEST[0][3][0][2][0][0][28]
04 HEX D2003A17010114FF494551303130393631382A1E3D090718033003FF004054549148E454FE4120412041204520452045204520452045204054549148E454FE4120412041204520452045204520452045204048566C44E455144120412041204520452045204520452045204048546C44E455144120412041204520452045204520452045204048546C44E455144120412041204520452045204520452045204048546C44E455144120412041204520452045204520452045204048546C44E45514412041204120452045204520452045204520
04 ASC [210][0]:[23][1][1][20][255]IEQ0109618*[30]=[9][7][24][3]0[3][255][0]@TT[145]H[228]T[254]A A A E E E E E E @TT[145]H[228]T[254]A A A E E E E E E @HVlD[228]U[20]A A A E E E E E E @HTlD[228]U[20]A A A E E E E E E @HTlD[228]U[20]A A A E E E E E E @HTlD[228]U[20]A A A E E E E E E @HTlD[228]U[20]A A A E E E E E E
05 HEX D20035DD010214FF494551303130383833362A1E3D09071803300CFF004448450845204520452045204520452045204520452045204520444845084520452045204520452045204520452045204520452044484508452045204520452045204520452045204520452045204448450845204520452045204520452045204520452045204520444845084520452045204520452045204520452045204520452044484508452045204520452045204520452045204520452045204448450845204520452045204520452045204520452045204520
I added line numbers in front and a hex and ascii conversion from it as well.
about addresses: on line 3, 4 and 5 the output starts with something which I believe is the address of the equipment. I think the 1st one (line 3) is the address of the Max gateway or a general system address, the other 2 (line 4 and 5) are the addresses of the 2 thermostats.
I have again done some investigation with wireshark (and a base64->Hex converter
) this evening (see attached file)
as already mentioned by you, the temperature is in steps of 0,5 degrees C.
I have trouble decoding the date when a particular end date (and time) for a command is set (after which the standard programs takes over again. I'm pretty confident I found the coding for the time and also for the temperature setting.
Temperature settings are always done with the temperature itself, not with "Comfort" or "Eco" I have "Comfort" set to 21 degrees; the command to the Max Gateway is exactly the same for : set to "Comfort" and set to 21 degrees.
the temperatures Eco and Comfort, but also other settings like boost setting and most important the week schedule can be programmed. I guess these setting are on one way or the other in the output after initiation of the session with the Max Gateway.
max trials3.zip
You do not have the required permissions to view the files attached to this post.
