I need files
Alles m.b.t. de Fritzbox plugin van Robert Hekkers (DUTCH forum)
Moderator: Digit
I need files
Postby Digit » Mon Mar 05, 2012 10:08 pm
I need some help. Not for myself, but for you. I wanna know if some code that I wrote, will also work on other models of the Fritz!Box. Mine is a 7170. I have a USB stick attached to the 7170, my 7170 web interface shows me this:
And when I use a DOS box and enter net use T: \\192.168.20.1\usbflashmemory-01 I can access the USB stick as drive T:
This is what my File Manager shows me:
I would like to have more versions of the files that are in the voicebox directory - your version!
In my case, the files are named config, lock and meta* . I need those.
As I said, I wrote some code that works fine on my 7170, but that's no guarantee for other models.
So, if you would like to help me testing, share those files with me and I'll remember your name when the beta stage starts :wink:
You can send those files to fritz@the-domain-listed-in-my-signature. Thanks.
One other thing: those who would like to prepare themselves for the next version of the Plugin: attach a USB stick to your Fritz!, so you can access those voicebox files just like I can; read-only will suffice.
You do not have the required permissions to view the files attached to this post.
Re: I need files
Postby Rutger » Tue Mar 06, 2012 5:59 pm
Mail sent.
Rutger
Re: I need files
Postby Digit » Tue Mar 06, 2012 6:54 pm
I see it, thanks!
Re: I need files
Postby jakkes » Tue Mar 06, 2012 9:21 pm
something is different on a 7390....
Is what i see on de webpage, but i do not see the folder voicebox appear on a mapping i made....
But i send the config file anyway...
jakkes
Re: I need files
Postby Digit » Tue Mar 06, 2012 10:24 pm
Thanks.
The voicebox is part of your current path, so you do have the directory.
And 2nd, this is from your browser, right? That's not going to help in the future, cause the Plugin will need a drive letter.
So there are no more files there, just the config file and the rec directory? What about the contents of the rec directory, maybe you can find those files meta* there? Or a directory level higher maybe?
Re: I need files
Postby jakkes » Tue Mar 06, 2012 10:28 pm
It seems that on the 7390 the voicebox is stored on the onboard flash (?)?
In de rec dir there is not a file.
When i make the mapping, I see files, but none of them is related to the fritzbox
jakkes
Re: I need files
Postby Digit » Tue Mar 06, 2012 10:28 pm
Oops, just to make sure everybody understands what I' working on: voicemail.... forgot to mention that :oops:
So if you don't have your Fritz configured with Answering machine turned on, you may not see all the files I am referring to... :x
Re: I need files
Postby Digit » Tue Mar 06, 2012 10:33 pm
Small update: I upgraded my own system this evening. Below is a small part of the touchscreen; the red is showing me the number of 'unplayed' voicemails :D
Re: I need files
Postby jakkes » Tue Mar 06, 2012 10:43 pm
I figured that out allready..... (about the voicemail)
I did configure the voicemail with the "wizard", but there is another option to be set:
Now i see the folder on my USB drive.
Including the config and the lock file.
Files send again...
jakkes
Re: I need files
Postby abl » Tue Mar 06, 2012 11:09 pm
Just sent a mail (for FritzBox 7390).
Thanks for considering other versions, much appreciated!
abl
Re: I need files
Postby Digit » Wed Mar 07, 2012 9:55 pm
Pff, for a moment I thought there was something wrong with my eyes, but it seems that there are little endian and big endian models (7390 is the 1st 'big' I have seen)
It's never easy with the Fritz! :x
Re: I need files
Postby pklijnjan » Tue Aug 28, 2012 5:03 pm
Digit kan ik de beta van de fritzbox plugin krijgen?
Ik wil hem wel eens proberen.
Peter
pklijnjan
Re: I need files
Postby Digit » Tue Aug 28, 2012 6:05 pm
Peter,
Ik weet inmiddels wat ik weten moest, beta testen is dus niet meer nodig.
Ik ben inmiddels bezig met de volgende versie, dus even geduld nog...
Return to Homeseer Fritz!box Plugin Forum
