Don't use AC door/window sensors
Moderator: b_weijenberg
Postby b_weijenberg » Fri Mar 30, 2012 1:27 pm
Do not use AC (HomeEasy,Chacon,KlikAanKlikUit,NEXA...) door/window and motion sensors in a home automation system!
These sensors are designed for stand-alone mode and produce for 3 to 5 seconds about 50 RF messages. This will disturb the RF signals of other sensors. If you send a command to an RFXCOM transmitter it will wait until the AC sensor has stopped transmitting. The reason for this is that it has no use for the RFXCOM transmitter to start transmitting if another sensor is active because both signals are disturbed due to the RF collision.
AC sensor transmits RF =================================================
                      |                                                | 5 seconds later the AC sensor stops transmitting RF
                      AC sensor received in application
                       Command to the RFXCOM transmitter - wait--------| RFXCOM starts transmitting RF
For door/window sensors the X10 DS90 can be used. This sensor can be used to trigger lighting commands and can also be used for security.
The preferred motion sensor for lighting control is the X10 MS13.
The X10 MS90 motion sensor can be used for security purpose only.
b_weijenberg
Re: Don't use AC door/window sensors
Postby Fischi » Mon Apr 16, 2012 8:29 am
Hi, does the DS 90 windows/door sensor send the data, if door/windows is open/closed to the RFCcom receiver ?
If yes, I could use it with homeseer.
Please answer me soon. Regards, Fischi
Fischi
Postby b_weijenberg » Mon Apr 16, 2012 9:56 am
Yes, the DS90 has an internal reed contact that can be used with the supplied magnet. The status open/close is transmitted.
And the DS90 has also a connection for a second external contact for example to connect another reed contact or microswitch.
b_weijenberg
Postby Fischi » Mon Apr 16, 2012 12:32 pm
Thanks for your answer,
is it also possible to take Visonic MCT-302, MCT-330, WT-301 or WT-302 sensors ?? (Where to buy ?)
Fischi
Fischi
Postby b_weijenberg » Mon Apr 16, 2012 12:39 pm
You can use the Visonic PowerCode sensor using this receiver as addition in the RFXLAN
http://www.rfxcom.com/receivers.htm#40079
b_weijenberg
Postby Fischi » Mon Apr 16, 2012 6:16 pm
thanks for your answer,
I will buy the DS90 door/windows sensors from Mamitek, but they are pricy /45€.
I use these in connection to the MAX! thermostats from ELV and controlling with Homeseer automation software.
The MAX! door/window sensors are cheaper/19€, but they don't work with the MAX! script in Homeseer.
Regards, Fischi
Fischi
Postby Theendisnye » Fri May 18, 2012 10:51 pm
Bert, which sensors are AC?
I had been using two types of home easy motion sensors at the moment a HE303 which appears to generate a single ON / OFF when viewed in xpl monitor and seems to also be usable with a dimmer. http://www.chbyron.eu/Byron/RemoteContr ... /42/HE303/
And an external motion sensor HE403 which has a house and unit dial and which appears to keep generating ON commands whilst motion is sensed and is specified as not suitable for use with dimmers.
http://www.chbyron.eu/Byron/RemoteContr ... /73/HE403/
I thought the first was an AC sensor and the second an ARC or have I got that wrong.
Can anyone recommend a suitable external motion sensor preferably at a reasonable cost?
Steve
Theendisnye
Postby b_weijenberg » Sat May 19, 2012 9:04 am
KAKU, HomeEasy, Chacon, NEXA... sensors with address code wheels (A-P/1-16) are ARC types and sensors with learning code are AC.
X10 MS13 sensors can be used outside if you protect the sensor for rain.
b_weijenberg
Postby Theendisnye » Sat May 19, 2012 9:44 am
Bert, I assume that the multiple ON/OFFs generated are not visible in an XPL Monitor window then?
Is it ok to use an ARC switch in a home automation set-up then?
Steve
Theendisnye
Postby b_weijenberg » Sat May 19, 2012 10:51 am
Multiple RF packets are ignored in xPLRFX and in the RFXtrx433.
The older USB and LAN receiver will send all received RF packets to the application.
The AC and ARC wall switches can be used as they transmit only packets as long as the button is pressed. Some switches have a maximum transmit time.
b_weijenberg
Postby mrqnapper » Thu Jun 28, 2012 10:01 pm
today I tried to create an RFX input device for the ms13E sensor in HomeseerPro. Did not succeed, it says no device found? I have set the code in the device to F3 and I also see that soem packaage is received in the Homeseer log. So what Am I doing wrong here? (also tried to create a normal device and choose form the list the Ms13A gave it the code F3 but that's not working either...).
So any advice how to get this working? Thanks.
W.
mrqnapper
Postby b_weijenberg » Thu Jun 28, 2012 10:06 pm
An MS13 is an X10 device and not an Input Device.
Set House Code F to STATUS ONLY on the RFXCOM X10 configuration page.
Create an MS13 X10 device F3 on the HS Status Page and it will show the state.
b_weijenberg
Postby mrqnapper » Fri Jun 29, 2012 12:04 am
Thanks, now its working. Is the shown state also the one for the light / dark sensor? Or is it possible to read that separately?
mrqnapper
Postby b_weijenberg » Fri Jun 29, 2012 7:25 am
light/dark sensor has the motion sensor address + 1 = F4
b_weijenberg
Postby mrqnapper » Fri Jun 29, 2012 8:10 am
Nice! Thanks.
mrqnapper
Next
Return to Rfxcom Receivers & Transmitters Forum
