Team,
What's the best alternative for my IRTrans LAN? (don't ask why
Thank you!
DJ
IRTrans alternative?
Re: IRTrans alternative?
I'm still waiting for my Neeo and I'm hoping for a nice API (which is promised). But Neeo is long overdue already.
groeten,
Does that work "just like the IRTrans LAN"?RdP wrote:Logitech Harmony Hub ?
I.e., if you send an IR command, will that immediately trigger an action in HS?
Or are there some disadvantages compared to an IRTrans?
Thank you!
DJ
Sorry my fault You're correct.
If you use it like that, it can not compare to IRTrans. There is no way to implement it in the current Harmony Hub plugin, because Logitech won't open up their API.
