I used HS3 and Z-Tool. Hence HS2 as sending and HS3 as receiving should be the same.raymonvdm wrote:
Did you use HS2 or HS3 for this ? My production is still HS2 and transfer has worked but migrate from secondary to primairy did not.
What went wrong when you tried?
I will look at HS forum. I think i wrote about my problem there.
Regards
Morten
Edit: Sorry I can't find it. I think I had a bad hour were I thought I had no primary and it was fixed by rebooting not only Homeseer but the OS. But I am not quite sure.
