1) you need to perform TMSetup once (see BeginTMEXSession in tmex.cpp)
2) you do need to read the two CRC bytes before the output is switched (see switch.cpp)
3) remember to add +5V
Function SetFlipFlop(S As Integer, RoMID As String, Fam As Integer) As Boolean
Dim Num As Integer
Dim ROM(8) As Integer
Dim flag As Integer
Dim romstr As String
Dim I As Integer
Dim CRCByte As Byte
Dim CRC16 As Integer
'// Start session
SHandle = -1
Num = 0
While (SHandle <= 0)
SHandle = TMExtendedStartSession(PortNum, PortType, vbNullString)
Num = Num + 1
If Num > 50 Then Exit Function ' This is just to break the function if we cant communicate with the 1 wire bus
Wend
'Soo now we have handle on the 1 Wire bus
'// check to see if setup needs to be done
If (Not SetupDone) Then
flag = TMSetup(SHandle)
SetupDone = True
End If
'Now we are going to lookup the DS2406 we wanna change
' We are looking for the RomID
If TMFamilySearchSetup(SHandle, state_buffer(0), &H12) = 1 Then
While TMNext(SHandle, state_buffer(0)) = 1
'// Read the ROM number
ROM(0) = 0
flag = TMRom(SHandle, state_buffer(0), ROM(0))
'// Check for the correct type
If ((Fam And &H7F) = (ROM(0) And &H7F)) Then
'// Create a string out of the ROM number
romstr = ""
For I = 7 To 0 Step -1
If (ROM(I) <= &HF) Then romstr = romstr + "0"
romstr = romstr + Hex$(ROM(I))
Next I
If romstr = RoMID Then
' If (TMStrongAccess(SHandle, state_buffer(0)) = 1) Then
' If (TMAccess(SHandle, state_buffer(0)) = 1) Then
flag = TMTouchByte(SHandle, &H55)
CRCByte = &H55
CRC16 = TMCRC(1, CRCByte, CRC16, 1)
flag = TMTouchByte(SHandle, &H7)
CRCByte = &H7
flag = TMTouchByte(SHandle, &H0)
CRCByte = &H0
' 31 00011111 A on B on = 001F HEX
' 127 01111111 A off B off = 007F HEX
' 63 00111111 A off B on = 003F HEX
' 95 01011111 A on B off = 005F HEX
'// Send the HARDCODED 00011111 to the Switch
flag = TMTouchByte(SHandle, 31)
CRCByte = &H1F
flag = TMTouchByte(SHandle, &HFF)
CRCByte = flag
CRCByte = flag
' End If
' End If
End If
End If
Wend
End If
End Function
