Plugwise Homeseer Plugin
Moderators: Rene, RdP
Wima
Post by Wima »
Oke solved it. It was another RTFM problem.
I put the statistics.xml in the HS dir instead of the plugwise dir.[:I]
Thanks.
Wil
Even the genious ask questions.
Reinder
Post by Reinder »
@ mgizmo I was just curious about the number.
Jeroen Bartels
Post by Jeroen Bartels »
Hey Rene,
Just bought Plugwise set last week and installed the source.
Now I installed your plugin (according to the instructions of jan 29) but I don't know how to get the plugs visible.
In the plugin selection I only see plugwise charts. Is this also the plugwise plugin or am I doing something wrong?
Thanx,
Jeroen
P.S. Is there maybe a manual for this plugin? if yes, where can I find it?
The plugs should become visible automatically. Did you configure the plugin via the Homeseer setup->interfaces menu? You should specify the IP address or host name of the Plugwise webserver.
To troubleshoot set the log level to debug (also via the set->interface menu).
Jeroen Bartels
But in the set-interface menu I only see Plugwise charts button. Where should I see the devices comming up? in the HS status page I would think...
The log says: localhost statisticsXML: de externe server heeft een fout geretourneerd: (404)niet gevonden.
Eearlier it showed 'niet gemachtigd' en dus heb ik het PW op de source en bij HS2 plugwise interface al disabled
Jeroen Bartels
I found the cause. I misplaced the statistic file in not in the WWW folder. (one level up.
It's working now. Thanx!
RobTdeBoer
Post by RobTdeBoer »
I have a few questions:
1 where can i download the plugin for plugwise
2 what version number is the newest at this moment.
3 if after yuo have installed the plugin how do you know if there is a newer available
@RobTdeBoer:
1. See http://www.domoticaforum.eu/topic.asp?T ... ge=4#14903
2. 0.3
3. Watch this forum ;-)
aeh
Post by aeh »
Hey guys, i installed the Plugwise plugin in my new HS2 application.
I have 2 problems now:
- I don't see the charts (HS logging gives no errors)
- My lamp is automatically going on after a few minutes.
Is there someone who can help me????
Here the debug information:
12-6-2009 21:57:38 - Plugwise - DEBUG: Plugin Config: Set loglevel to 3
12-6-2009 21:57:38 - Plugwise - DEBUG: Plugin Config: Saved loglevel configuration to database
12-6-2009 21:57:43 - Plugwise - DEBUG: Query: http://localhost:8080/statistics.xml
12-6-2009 21:57:43 - Plugwise - DEBUG: Parsing statistics.xml
aeh
Post by aeh »
OK, its official. I am a stupid old cow.
I saw it finally after reading it for the second time in the forum.
"Total usage" and "Actual Usage" are links.[:I]
Now I have only one problem left.
Who can help me.
aeh
Post by aeh »
Is it possible to place the actual usage besides the bars in the charts? I know i can see it when i hoover over the bars but it's nice to see it right away.
@aeh: You have to edit the actual.aspx file in the html/Plugwise directory. Replace:
ToolTipText=""#AxisXLabel: #YValue W""
with
LabelEnabled=""True"" LabelText=""#YValue W""
aeh
Post by aeh »
It doesn't work.
Do i have to restart one of the applications?
aeh
Post by aeh »
Ok, it works. [:)]
A restart of the browser was enough.
aeh
Post by aeh »
Strange phenomenon, my LCD tv is off and it still uses 2,01 Watt.
The actual usages reacts very slow.
The tv is off for a while and the graph still says 211,4 Watt.
Why?????
