Ziggo Cable Internet 50MB down 5 up
Tell me more
Did you connect an ATA interface (which) to the PSTN outputs on the DOCsis modem?
First I go on vacation Then I order Ziggo 50/5, but I want to be able to log the voip calls from ziggo, not sure if this is possible?
Setup:
Linksys SPA941 Voip Phone (4 lines desktop in my office)
Sonom M3 Dect system (Gigaset 301 before but crap) with Siemens and Sonom handsets
Linksys SPA3102 for connecting my analogue line calling in and out (UPC modem)
Linksys PAP2T voor connecting my doorbell (=analogue phone) and other analogue phones
3CX Voip server running on my dual atom mini ITX board server, running WSRV2008 R2 and also working as router
hoezo bereikbaar:-)
How did you connect this? the SPA connected to the POTS outlet on the Docsis modem?
Just to make you guys aware:
If you are running your own mail server at home you will need to look for an alternate solution; Ziggo blocks incoming port 25. There used to be a solution with incoming mail relaying for former Multikabel customers, but officially this is no longer supported. I'm still waiting for a firm confirmation from Ziggo that they will put a replacement solution in place.
Are they still doing that!
Thanks for the info
Thanks for the info
I can relay your mail if you want to (to an other port).
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mgizmo</i>
<br />I can relay your mail if you want to (to an other port).
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">And read it if you want
<br />hoezo bereikbaar:-)
How did you connect this? the SPA connected to the POTS outlet on the Docsis modem?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yup, connected to the analogue phone output of the modem. You can even specify if it is FSK or DTMF so I could throw away my converter too.
BTW UPC lets me pay extra for sending the CallerId over the line....
Does anyone know what cablemodem Ziggo will use? (brand and/or type)
DJ
DJ
Just installed my new modem..
not all the site are working at the moment..(like google.nl is not accessible)
download speed is 50mb..up is still 3mb.
I hope in 1 hour all works well including higher upload speed.
Why is not working directly?
Once you have internet al sites should work, or is Ziggo using a proxyserver?
Can you also tell the type of modem you have
succes
succes
- Snelvuur
i assume i have the correct modem, but i cant really say i reached more then +- 3mb/s down, and more then +- 350kb/s up.
Not sure what the problem was.
www.google.nl and www.ziggo.nl was not working
all was working fine after 60 min
Upload speed is still limited to 3mb
download is 50mb
I forgot the modem brand..it's different one..Will post that later.
download is 50mb
just reset the modem again (off/on)
it's a ubee modem or a arris modem
