Jeenode + roomboard: switching output from Homeseer
Moderator: Mdamen
Re: Jeenode + roomboard: switching output from Homeseer
Yes, but...
It would mean a complete 'makeover' of both the sketch and the Homeseer scripts.
nawikre
Post by nawikre »
Oke...so it actually means writing new script and sketch. And i am no programmer so that is impossible for me to do....
IF someone wants to put in the effort to do this, I (and many others) are very greatfull....
but i think i should open a new topic for this issue??
Iwan
greetz,
Iwan
Using Arduino's or comparable cannot be done without at least a bit of programming experience, so I don't get it...
You can open a new topic, but don't expect too much - speaking for myself, I'm not gonna invest time in "Arduino via USB" Homeseer Integration when JeeNode & Homeseer integration already exists.
And in my opinion, a JeeNode with RF is much more suitable as sensor node as the "original" Arduino. If I were you, I would get hold of 2 JeeNodes, put the Arduino on Marktplaats (or keep it for misc. testing purposes would be a better choice) and you (and those many others) are almost done... am I right or not?
If not, please say so :)
nawikre
Post by nawikre »
Digit wrote:Using Arduino's or comparable cannot be done without at least a bit of programming experience, so I don't get it...
oke, that is a real option, but the next question will be....What IF i only need a jeenode with temp sensor and not a whole roomboard with motion detection and light.
Iwan
greetz,
Iwan
Buy the thermo plug (board only) and a DS18B20, more details here
nawikre
Post by nawikre »
Rene wrote:Buy the thermo plug (board only) and a DS18B20, more details here
oke, but what about humid sensor, because it would be perfect to have temp and humid
thanks, this option is a very good one.
Iwan
greetz,
Iwan
SHT11, S555TH can do that.
For SHT11 you could use the Room Board.
Another resource: http://www.jansipke.nl/measuring-temper ... -a-jeenode
Including sketch 8)
I found that one with the help of an Internet search engine :wink:
nawikre
Post by nawikre »
Digit wrote:SHT11, S555TH can do that.
Including sketch 8)
thank you very much......i use an old search engine, so it did'nt popup ;-)
i have looked at the link, but the are connecting a extra/different radio. type RX868 for recieving the data from a external (big) temp/humid sensor.
what i actually wanted was like the jeenode roomboard without pir and light. (without having to buy the roomboard and pull the other 2 modules of the board.
Iwan
greetz,
Iwan
nawikre
Post by nawikre »
i finally get the picture.......
you have the jeenode...and as extra you have the roomboard that you plug intoo the jeenode to make 1 set. So you have to buy these 2 things seperatly.
so i can take a jeenode and a seperate temp and humid sensor to plug it into the jeenode.....
am i right??
Iwan
greetz,
Iwan
esschenk
Post by esschenk »
Yes right thats all you need
http://jeelabs.com/products/jeelink
http://jeelabs.com/products/jeenode
http://jeelabs.com/products/room-board
Maybe you can ask Jean if you can buy only the roomboard with the Sht11
else you can buy only the roomboard pcb and buy the sht11 somewhere else
http://cgi.ebay.com/SHT11-Humidity-Temp ... _500wt_922
Good luck
Ed
nawikre
Post by nawikre »
esschenk wrote:Hello,
Good luck
Ed
this is the answert i was looking/hoping for....
thanks, Ed
greetz,
Iwan
