Team,
I've been searching everywhere, including the HS3 documentation -- without result.
Q: What is the "Technology Address" in HS3?
- What is it used for
- Why can't I find so little information about this field?
Cheers
DJ
HS3 - "Technology Address" ?
Re: HS3 - "Technology Address" ?
The technology address is nothing more then the combination of the device address and the "old" X10 housecode/devicecode. See the first tab of a device, It is called Address and Code.
The Address is often set by a plugin that owns the device. The Code can normally be set by the user.
Some script function can use the device Address, the device Code or a combination (the device Technology Address) for identifying devices.
Thank you Stef!stefxx wrote:The technology address is nothing more then the combination of the device address and the "old" X10 housecode/devicecode. See the first tab of a device, It is called Address and Code.
