Hi everyone.
I am looking to get a 9 Pin D-Sub female that will plug into a USB to RS232(Male) cable. The USB end is connected to a PC. I will be looking to connect individual pins from the RS232 to circuit board that has a microcontroller (PIC). It will most likely be bare wires on the other end of the D-Sub. The idea will be to send a signal from a PC, via a USB to RS232, which then splits on the D-Sub onto various pins on the circuit board.
I have previously had a D-Sub which allows you to solder wires into the back of the D-Sub, and also has a casing to close the D-Sub up once you have finished soldering the wires. I can't find this now, can anyone recommend one? I have been looking through RS and Farnell and there is all sorts of different options such as filtering etc. I don't know which one will be best for the purpose I am using it for
Also i am looking for pins and sockets that can fit over a D-Sub male and female connector pin, the ones that you crimp onto wires, and also the crimping tool. Can anyone recommend anything?
Suggestion for connecting a USB-to-RS232 cable to a PIC
Forum about all other NON Home automation stuff can be placed here....
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
