difference Remeha Calanta and the Remeha Calenta Ace rj11
Posted: Sat Nov 17, 2018 4:31 pm
by labium
I have a Remeha Calenta and a half year newer Remeha Calanta Ace. They both have a rj 11 service jacket. the rj11 of the Remeha Calanta is serial and works , but i cant get a serial communication going on the Remeha Calanta Ace. Does some know if the Ace rj 11 is a 4 wired network entrance ? . The newest Aces do have a RJ45 entrance.
Re: difference Remeha Calanta and the Remeha Calenta Ace rj11
Posted: Tue Feb 02, 2021 11:50 pm
by sincze
Anyone with an update
interested in this as well.
Posted: Sat Feb 06, 2021 3:29 pm
by D_Hailsham
The original Calenta supported Opentherm controllers, including Smartpower, and on/off controllers. The newer Calenta Ace uses R-bus, which is used by the Remeha eTwist controller. It still supports Opentherm, Smartpower and on/off controllers. The eTwist can be used with Apple and Google Apps to remotely control the system.
Posted: Sat Feb 06, 2021 7:31 pm
by sincze
Ok, tnx. The RJ11 seems to be general service port on the Remeha series where this topic seems to be about.
So reading the RJ 11 on Calenta Ace.
Currently have my Calenta ACE via OTGW to a Honeywell Chronotherm Modulation round working.
Tried Calenta ACE via OTGW to ETWIST..... that seems an issue. ETWIST won't switch on.
Posted: Sun Feb 07, 2021 3:21 pm
by D_Hailsham
Is the eTwist gateway also connected? If so, try disconnecting it and connect the eTwist controller OT terminals direct to the OTGW. The eTwist can be used with or without the eTwist gateway. You just lose the app/wireless functionality.
Posted: Mon Feb 08, 2021 2:29 pm
by steffenklein
sincze wrote:Currently have my Calenta ACE via OTGW to a Honeywell Chronotherm Modulation round working.
Sounds very interesting. I am currently investigating to read my Calenta ACE 25DS.
Could you tell me which OpenTherm Gateway you have used and where you have connected it - to the R-Bus?
Steffen
Posted: Mon Jun 07, 2021 10:26 am
by jgeo
It seems like Remeha dropped the serial interface (2021 Remeha Calenta Ace 40c), and now the RJ connector on the front uses a 1 MHz CAN Bus (2.5V I/O signal).
