Just connect a standard sensor to the gas input line of the boxx module and it should work. Make sure the sensor is well centered on the watermeter so it shows the wheel inside it spinning around (reflecting the sensor light when it makes a turn).rleunk wrote:Hello, got a boxx meter module and got it connected to my Toon, saw that some off you have it working also, is this with the standard optical sensor?
Or has someone managed to use another sensor?
From sometime ago I had a Sensus HRI-A4 pulse sensor lying around, now I am trying to figure out if I can connect this to the boxx module to read the watermeter.
Someone got an idea if this is possible and how to connect it?
also enable <FT_WaterInsights_rel>1</FT_WaterInsights_rel> in the file /qmf/etc/qmf_tenant.xml
