Boiler not connected
Posted: Tue Dec 05, 2023 1:14 pm
I would like to ask you a few questions about the OTGW.
After inverting the thermostat and the boiler connections on OTGW just to test, I cannot see the boiler anymore. Is it possible that I broke something on OTGW ? My boiler and thermostat still work together without OTGW.
I've installed the diagnose firmware on PIC, and here is the voltage levels result (test number 5 with boiler connected) :
Power supply: 3.276
Reference: 1.446
Thermostat: 2.936
Boiler: 0.000
Is it normal ? If not, do you think my nodo shop otgw is broken ?
In complement, I got these results :
Enter test number: 4
OK1A high-to-low: 11.25us
OK1A low-to-high: 22.75us
OK1B high-to-low: 8.50us
OK1B low-to-high: 4.25us
Opentherm gateway diagnostics - Version 2.1
1. LED test
2. Bit timing thermostat
3. Bit timing boiler
4. Delay symmetry
5. Voltage levels
6. Idle times
Enter test number: 5
Power supply: 3.276
Reference: 1.446
Thermostat: 2.124
Boiler: 2.773
Reference voltage setting (0..9) [5]: 5
1. LED test
4. Delay symmetry
5. Voltage levels
6. Idle times
Power supply: 3.276
Reference: 1.446
Thermostat: 0.783, 2.127
Boiler: 2.757
Reference voltage setting (0..9) [5]: 0
Then :
1. LED test
4. Delay symmetry
5. Voltage levels
6. Idle times
Power supply: 3.281
Reference: 1.448
Thermostat: 0.724
Boiler: 0.000
Power supply: 3.276
Reference: 1.446
Thermostat: 2.936
Boiler: 0.000
1. LED test
4. Delay symmetry
5. Voltage levels
6. Idle times
Power supply: 3.276
Reference: 1.446
Thermostat: 2.124
Boiler: 2.773
1. LED test
4. Delay symmetry
5. Voltage levels
6. Idle times
Power supply: 3.276
Reference: 1.446
Boiler: 2.757
Then :
1. LED test
4. Delay symmetry
5. Voltage levels
6. Idle times
Power supply: 3.281
Reference: 1.448
Thermostat: 0.724
Boiler: 0.000
