I bought an OTGW at Nodo shop. Ready-made programmed and with WiFi.
I placed this between the Remeha eTwist (without gateway) and the Elga Ace.
The transistor 1 of the PCB immediately burned out, because the R-bus of the Elga apparently (sometimes) emits too high voltages and that R-bus does not automatically switch to OpenTherm.
So.... after Nodo-shop repaired the PCB, I installed the OTGW again after installing a Remeha Gateway 16 (From R-bus to OpenTherm).
But again it doesn't work properly.
According to the Debug Information, the OTGW now sees the Thermostat and the Boiler, but not the OTGW itself.
Does anybody have experience with this?
Or can someone give me some suggestions on how to proceed?
OTGW between eTwist and Elga Ace causes problems
Questions, suggestions or remarks about this forum.
Moderator: TheHogNL
- Starting Member
Return to “Suggestions, Questions & Feedback”
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
