Page 1 of 10
Ziggo Cable Internet 50MB down 5 up
Posted: Tue Jul 07, 2009 10:51 pm
Ziggo just updated the website with the new cable speeds and the Docsis 3.0 modem.
I think I will trade one traditional ADSL line in for this cable type.
Which one it will be? Xs4all or Telfort?
Any one some experiance with the new speeds and Docsis 3.0 modem?
Posted: Tue Jul 07, 2009 11:00 pm
by TANE
I'm waiting for my new modem...
They have none in stock at the moment.
The max download speed of this modem will be 250mb in the future.
Posted: Tue Jul 07, 2009 11:03 pm
Yes later this year Ziggo will go up to 80 or 100!
Is the cable modem any good or did you set it to bridged?
If bridged any problems with setting up the voip on another router?
Posted: Tue Jul 07, 2009 11:10 pm
by TANE
I have connected to Fritzbox..no problem at all
Also the phone part from ziggo modem is connected to Fritzbox.
I hope that the Fritzbox 7270 can handle 50Mb.
I know that the Wan port can't do that (Adsl2)
Since I'm using one of the Lan ports as wan 50 mb should not be a problem..(i hope)
else i I will upgrade it the the new fritz box 7370..later this year availible.
Posted: Tue Jul 07, 2009 11:14 pm
I think it will work, lets see
so you have set your Ziggo modem to bridge?
Posted: Tue Jul 07, 2009 11:25 pm
by TANE
You can't access the modem
Modem is installed as bridge
It will always forward the Internet Ip to the first connected device.
Funny thing is when you connect a single machine to the modem and install Vmware on this machine...all the VM's will get a real Ip address.
Posted: Tue Jul 07, 2009 11:29 pm
Ok that is right it's gets the real IPNR does not matter if that is a Computer. Same here with ADSL if I connect directly a laptop to the modem.
Question: how is the voip handled with ziggo then, a seperate voipmodem?
Posted: Tue Jul 07, 2009 11:33 pm
by TANE
Nope same modem with two pstn outputs.
Posted: Tue Jul 07, 2009 11:43 pm
In other topics I red you connected those pstn outputs with the Fritzbox?
Posted: Tue Jul 07, 2009 11:50 pm
by TANE
yep..some problems with connection...
if used correct cables all works well.
To save power and reduce the number of power adapters:
Ziggo modem, Fritzbox, Lava Device server,Belkin USB are connected to one 12 volt adapter of 3,8A
usage is 17 watt
Posted: Tue Jul 07, 2009 11:57 pm
OK but on which port of the Fritzbox did you connect the pstn output from the ziggo modem?
Posted: Wed Jul 08, 2009 12:11 am
by TANE
PSTN from Ziggo modem is connected to DSL/Tel with the special Y-cable delivered with Fritzbox
Available output on the FritzBox
2 x PSTN out
1 X ISDN S0 out
4 Lan (when using as rout without ADSL you can configure one of the lan ports as WAN port.)
1 Wan (ADSL 2)
Posted: Wed Jul 08, 2009 12:14 am
OK now I get it
Thanks
Posted: Wed Jul 08, 2009 12:17 am
by TANE
Don't forget the Fritzbox plugin for Homeseer..
Posted: Wed Jul 08, 2009 12:20 am
[:D]
