Last week I started with a new challenge.
Combine all the data and media files on one system.
I started with
Qnap 119P
1.2 GHZ CPU 512 mb memory
2 TB WD green HD
It was performing well for the normal usage.
streaming media
Downloading (SABNZBD) great!!!
Adding camera recording was a challenge...The CPU power is just to low to let all the jobs run at the same time.
Today I replaced the QNAP 119 whit the QNAP 239pro
1.6 Ghz Intel Atom 270 CPU
1024 Mb Memory
2 disk Samsung F2 1.5TB
All the task can be run simultaneously..nas is still performing well
Power Usage is much higher..
119p +/- 14 watt
239Pro +/- 26 watt
The pro can also scheduled turned on/of including wake on LAN.
Also build in VGA port ( It's a PC running Linux)
There are some other nice QPKQ plugins
SABnzbd+
Squeeze Center
MLDonkey
WordPress
Joomla
XDove (Mail)
more....
Other Options
Webserver (including mysql)
Itunes server
Surveillance Station
MultiMedia
more
Shop
http://www.wifimedia.eu/catalog/qnaptur ... p-773.html
Support from WifiMedia is great.
I was there today for testing different boxes including power usage.
Conclusion:
If you are looking for a good NAS go for the QNAP 119
If you need also IP camera recording go for the QNAP 239pro
@snelvuur: QNAP Turbostation TS-439U-SP (1,6GHz, 1GB) 19" (4 disk raid 5 6TB)
Camera recording screens
QNAP 119 & 239 Pro
Moderator: Esteban
- Snelvuur
QNAP 119 & 239 Pro
@chak: hmm 4 disks, still leaves me 6tb with 2gb drives (raid-5)
QNAP 119 & 239 Pro
you can go for the 8 disk version..
QNAP 119 & 239 Pro
Chak, does it manage every lan camera or a selected list? thanks
QNAP 119 & 239 Pro
List of cameras
I think the generic will work for most of the IP cameras
I have connected to the Axis Ip server Q241
Option Axis 206 is working fine
[img]uploaded/Chak/2009827233518_camlist.png[/img]
[img]uploaded/Chak/2009827233542_camlist2.png[/img]
QNAP 119 & 239 Pro
I've got the Qnap 119 model and it is a very very good Nas. No fan, no noise, low power, very quick transfer speeds (main reason for buying)
Never managed to run out off cpu power, although I only have one camera recording, and I don't really have a need to record to disk.
As a well designed embedded Nas it is a very interesting product, just kinda works.
Only niggles are really small ones that I'm sure over time will be fixed by new software releases ie external disk as NTFS performance is poor, (so just use EXT3) Also the odd rogue task from twonkymedia registering cpu as full, but it remains responsive.
Also mySql seems to work just fine for me, but I'm not throwing much data it.
Best NAS I've ever had, don't see any need to go for multi-disks and higher power. (I have had quite few over the years!)
[:D]
[:D]
