multi broadcast axis 241s
Moderator: Esteban
Katsie
Post by Katsie »
i received 2 axis 241S video servers.
i was looking on google for ''multi broadcast''
what i want is , i want to show the cctv cam on the www , not for only 20 peeps max, but for the whole world :P.
this is easy with an IPcam from axis, but i can't find any options for the video server.
any ideas?
(the video servers were free of charge because of a lightning strike, only PSU was broken ;) ) lucky me
Esteban
Post by Esteban »
Hi Katsie,
Are you sure more than 20 people will be looking at your cam at the same moment in time? Does the site you plan to put it on have such high traffic? If so you could have a webserver do the work, then you're dependent on the webserver's bandwidth, not the Axis'. Anyway Axis has a lot of reading material in PDF format, I suggest you have a look in there.
Like here for example:
http://www.axis.com/techsup/faq/publishing.htm
Ciao,
Esteban
