IP Camera
Moderator: Esteban
abl
IP Camera
Post by abl »
I'm going to the USA for a few days and wanted to know whether the US IP camera's can be used in Europe. Should I go for power over ethernet or can I use any powered camera?
IP Camera
Problem in the USA is find the shop where you can buy a good Ip camare for a good price.
Look for Best buy / Tiger direct.
For POE you will also need POE switch.
abl
IP Camera
Post by abl »
Amongst colleagues this is a very popular shop (in New York):
http://www.bhphotovideo.com/
When you want to check you should be very fast as this is a shop run by jews and they don't work at saturday (even webshop is closed).
Direct link to ip cams:
http://www.bhphotovideo.com/c/buy/IP-Ne ... 4293342867
Esteban
IP Camera
Post by Esteban »
US cams should work fine as long as you check the voltages. You might have to replace the power adapter with a European one.
Noel
IP Camera
Post by Noel »
Nice one abl,
I'll be in NY beginning next month, and I'll for sure go to this shop..
Mversluis
IP Camera
Post by Mversluis »
YOu don't need to have a POE switch to use POE. There some little adapters to created POE not on the complete network. But only by the devices with need one.
I think you can buy those for 10 -15 euro's
We used them alot within a callcenter infrasturcture , where the building has to old wired cables to used POE.
Best regards,
Marco
Peterpc
IP Camera
Post by Peterpc »
When you buy an American camera, be sure you can put it to 50 Hz and not only 60 Hz, 60 Hz will give you a flickering screen with the lights on.
Snelvuur
IP Camera
Post by Snelvuur »
i've even ordered at http://www.bhphotovideo.com/ , they still send me a big book all the way from the states about new items.. pretty weird
