I am anxiously waiting for the mounting frames that allow Duwi z-wave modules to be placed in Bush-Jaeger switches. A while back ezHome mentioned that is coming soon. But since patience is not my strong side, I have been scaving the net for more information and found:
http://www.zwave4u.com/products/en/Swit ... witch.html
So it is actually available. There is also a press release that Duwi is supposed to make these mounting frames. But on the Duwi website i can not find anything.
My big question is the mounting frames mentioned in the link before are for in wall modules. I can not find anything for the wall controller. Is there anybody out there who knows more then me (about this subject [:D]).
I have money burning in my pocket[:p], but i don't want to replace all my current wall switches.
Bush-Jaeger / Duwi integration
Haha i hit the post switch, hear a notification on my phone and its ezHome, with the News he has a sample.
Yes I do have the sample and I will have a look at it this weekend.
I'll make a post on our forum www.ezhome.nl/forum and I'll post it in here to.
Let's make z-wave EZ
Last week I got a bunch of duwi switches, which were intended for the garage. But my wife asked me if i could use me PIR to control the front porch light. So I did. But since the original porch switch is in a 2 switch Bush-Jaeger mounting frame. I had a challenge. The challenge got bigger when i discovered that no null wiring was available. I tried to pull wires through the original tubing, but somewhere I got stuck. After some cursing i found a workable scenario:
1) grab a dremel adapt the duwi 05443 mounting plate so it fits inside the BJ mounting plate
2) keep hold of the dremel adapt the BJ mounting plate so the duwi swich plastic fits.
3) short the switching wire with the phase wire
4) place a duwi switch inside the lighting housing
Ofcourse it's twice as expensive since i have to use both a switch and a 05433 button, but since pulling wires was no option, it was the second best option. The end result is pretty good (if i say so myself), although you have two styles of switches in one frame. I intended to upload a picture, but i found out that this forum does not have an upload area...
@Emiel:
Sorry for not keeping you up2date, I received the first working and fitting device, I am waiting for the dimmer and blinds models that's why I didn't post anything.
So it's comming in the next comming weeks,...... Maybe something for Santa?
For which modules will it be available? Also for the battery operated 05443?
Buying a fitting module will be easier then dremeling for an hour to make a nice snug fit. Ofcourse it will not make you as proud as this hack makes me .
Re: Bush-Jaeger / Duwi integration
Is there any News on these switches?
Because I cant find or buy them anywhere.
Yes there is News about them:
The switches are available from 2day.
The first modules are:
Dimmer
Switch
Blindscontrol
The walltransmitter will be released in a few weeks.
Dimmer
Switch
Blindscontrol
Take a look at our new webshop www.ezhome.nl
Hey, that's great News. I will wait until the wall transmitter is there, but I will start scraping all my money .
