Hi
I need help to configure Visonic Sensors and a Cent-a-meter on Domotiga, using RFXCom receiver.
What values go where ? Any examples ?
Thanks,
m
RFXCom Visonic and Cent-a-meter howto?
Moderator: RDNZL
- RDNZL
Which type of sensors do you have?
The decoding part is included, just not all possible sensor types are defined yet in the database, I will add them if I know the types.
Hold on a bit.
Ron.
Hold on a bit.
Ron.
I have an OWL CM113 (RFXcom compatible) and a some Visonic movement (Discovery K9-80) and window/door sensors (MCT-302T). They all work with RFXCom and I am using the Visonic sensors with xAP (32-bit mode). In variable length mode, DomotiGa receives and decodes RFXCom's data (I can see it in the log). My only problem is how to configure Domotiga to use this data.
I simply suck in programming/data base stuff.
Update: the new DomotiGa version, 0.1.176, has the CM113 working, will test the Visonic asap
Thanks Ron, you are the best!!!
thanks,
m
thanks,
m
