After having explained the Powerline/RF issue...back to my quest.
Indeed Homeseer/Windows is the biggest problem in the stability of my system. Although Powerline X10 is still slow, and the hardware is not always reliable. Even worse... Xanura is EOL.
If I go for a KNX based system, my options so far are:
1) I could build my own X10>KNX gateway so I can leave my Xanura implementation in tact. Each Xanura device should be presented as a KNX device on the KNX bus.
CER has a nice platform for this (FieldCommander). €400 for the box, €400 for the X10 module, €400 for the KNX module, and some programming hours.
- or I could develop a program which does an KNX/IP to Xanura datagram translation, and use the PMIX35 to translate KNX/IP and send X10 over the Xanura Powerline network.
2) I could refit the complete Xanura network with Powerline KNX/EIB components. The gateway alone is almost €700, and all the hours for the electrician to do the refitting might be expensive. Then there is the replacement of the phasecoupler and the linefilters for powerline EIB which is around €200 for a three phase system (cheaper then Xanura
One problem with Powerline EIB dimmers from ABB (only one I found so far) is, they have a max powerrating of 210VA (~200watt). Which in some cases would be problematic as I have some high power halogen lights in my office and livingroom.
IF I go for the Gira Homeserver for interaction and visualisation (or some other KNX system), I have to build a KNX bus. This means I have to buy some base components: A line coupler, programming interface and powersupply which will cost me around €750.
Some other integration trouble I have to think about:
- Integration with my Networx alarmsystem (RS232)
- Integration with RFXCOM (sensors, I/O dooropener, KaKu and Harrison interaction)
Looking at all the extra's being introduced in Gira's latest update (29-4-2010), this is still my preferred system. Domotiga is a nice alternative but if I have to develop the interfaces for my alarm and RFXCOM, I'd rather put that time in an interface for Gira Homeserver.
