Click on/Click off door/windows sensor works?
Postby iamjwk » Sat Oct 06, 2007 1:52 pm
I bought a AMST-606 KlikAan/KlikUit (ClickOn/ClickOff) at the Dutch Gamma store for 13 euros to try it on RFX receiver.
Should the signal of this device be received by the RFXcom receiver? I do not see any signal with the receiver program.
Jan-Willem
iamjwk
Postby b_weijenberg » Sat Oct 06, 2007 2:04 pm
This type of sensors can't be received by the RFXCOM receiver.
Only the KlikOn-KlikOff "lighting" transmitters and remotes can be received.
The KlikOn-KlikOff security sensors transmits very long packets for a long time. It is therefore not a good idea to use this type of sensors when using X10 security sensors, X10 motion sensors or X10 remotes. The chance for data collisions is too high!
Bert
b_weijenberg
Postby iamjwk » Sat Oct 06, 2007 2:24 pm
OK, thanks for the answer.
iamjwk
Postby genoenhuis » Tue Feb 26, 2008 2:34 pm
what about the new updates for the receiver. Is it still not possible to receive the AMST-606 with the rfxcom receiver?
what kaku devices are supported today?
genoenhuis
Postby iamjwk » Sat Aug 23, 2008 2:18 pm
Last update: this sensor works with the latest firmware for RFXCOM receivers. I bought some at the Dutch Gamma store for around 13 euro. Be aware that the visonic sensors are better as they give a signal each hour, while the kaku only sends status changes. But may be good enough for several cases.
iamjwk
Return to Rfxcom Receivers & Transmitters Forum
cron
