An very effortable solution to have different streaming music in every room for about $69,-
http://new.orb.com/en/music/features.html
Orb MP-1 Music in everyroom effortable
Moderator: TANE
Re: Orb MP-1 Music in everyroom effortable
Looks like a nice solution. Can even be better if it's possible to stream Homeseer audio (TTS) to the Orb's. Any suggestions on this?
Herbus (Jos)
I have no experience with this but it might do what you want.
Virtual audio cable
http://software.muzychenko.net/eng/vac.htm
Virtual audio cable
With that software you need: one pc for each room. Orb is better ! Now i'm testing a small card indipendent from pc , that works on lan cable (client+server), the first card has AUDIO IN , the second card has AUDIO OUT , the second card can be everywhere in the world , because it uses tcp/ip , and you can have many many receivers all connected to the audio source. The source can be everything just with a 3.5mm plug (mono or stereo). So i could hear HS announcements in the home , on holidays in my hotel room, or at work !
Drmacchi, it='s very interesting !
could you tell us more?
Where can i find this card?
thx
thx
@Fselan, i've an active topic about that here
http://www.domoticaforum.eu/viewtopic.p ... +ip#p39118
There, you will find the link to the card . price is 72 euro.
Now i'm creating a small plastic box for it. i have 2 pieces to test : client and server. cards are identical and you set the role by a simple switch on the card
ciao!
ciao!
