Page 9 of 9
Re: Homeseer Script to monitor & Control ELV MAX! Thermostats
Posted: Sun Nov 09, 2014 7:59 pm
by mhn
Hi Fischi.
Version: 02p 20130211 on HS2. I changed TCNT in linie 76 from 20 to 100.
I never lost a thermostat. I think that's a problem with firmware before 1.4. I bourght mine with 1.4
If you find a 1.4 firmware file I know another MAX user that miss it.
Regards
Morten
Posted: Tue Nov 11, 2014 7:41 pm
by JoopK
© eQ-3 AG 2013. All rights reserved. MAX! Version 1.4.1
But I still loose the Thermostats every now and then....
Posted: Tue Nov 11, 2014 9:00 pm
by Fischi
Hi JoopK,
I thought that 1.4.0 or 1.4.1 and the cube firmware update would solve the issue but it doesn't seem so.
I think it's a hardware (cube) problem. I have 2 cubes, both loose the radiator thermostats anyhow.
I will stay with 1.3.4 .
Regards, Fischi
Posted: Sun Dec 07, 2014 11:46 am
by PuNiSHeR
hello,
I just bought the license for HomeSeer Pro 3. I also have a problem.
In the logs, I see the 6 thermostat valve appears, but the list of device, it misses 2.
nov.-13 10:39:36 Max_debug1 M: #Devices: 6 DeviceType: 01 DeviceAddress: 808383 SN: KEQ0917699 DeviceName: Bureau DeviceRoom: 6Room Name Bureau
nov.-13 10:39:36 Max_debug1 M: #Devices: 6 DeviceType: 02 DeviceAddress: 904128 SN: KEQ1032468 DeviceName: Chambre 2eme DeviceRoom: 5Room Name Chambre 2eme
nov.-13 10:39:36 Max_debug1 M: #Devices: 6 DeviceType: 02 DeviceAddress: 904613 SN: KEQ1035670 DeviceName: Chambre 1er DeviceRoom: 4Room Name Chambre 1er
nov.-13 10:39:36 Max_debug1 M: #Devices: 6 DeviceType: 01 DeviceAddress: 808028 SN: KEQ0917513 DeviceName: Cuisine DeviceRoom: 3Room Name Cuisine
nov.-13 10:39:36 Max_debug1 M: #Devices: 6 DeviceType: 01 DeviceAddress: 680107 SN: KEQ0456385 DeviceName: Salon DeviceRoom: 2Room Name Salon
nov.-13 10:39:36 Max_debug1 M: #Devices: 6 DeviceType: 01 DeviceAddress: 680128 SN: KEQ0456371 DeviceName: Salle de Bain DeviceRoom: 1Room Name Salle de Bain
nov.-13 10:39:36 Max_debug1 M: #rooms: 6 RoomNumber: 6 RoomName: Bureau 1stAddressInRoom: 808383
nov.-13 10:39:36 Max_debug1 M: #rooms: 6 RoomNumber: 5 RoomName: Chambre 2eme 1stAddressInRoom: 904128
nov.-13 10:39:36 Max_debug1 M: #rooms: 6 RoomNumber: 4 RoomName: Chambre 1er 1stAddressInRoom: 904613
nov.-13 10:39:36 Max_debug1 M: #rooms: 6 RoomNumber: 3 RoomName: Cuisine 1stAddressInRoom: 808028
nov.-13 10:39:36 Max_debug1 M: #rooms: 6 RoomNumber: 2 RoomName: Salon 1stAddressInRoom: 680107
nov.-13 10:39:36 Max_debug1 M: #rooms: 6 RoomNumber: 1 RoomName: Salle de Bain 1stAddressInRoom: 680128
nov.-13 10:39:36 Max_debug1 H: Cube Serial number: KEQ0565484 Cube Address: 744128 Cube Firmware: 275 Cube Date: 13/11/2014 10:39:00
nov.-13 10:39:36 Info H: Cubedate: 13/11/2014 10:39:00 systemtime: 13/11/2014 10:39:36 Datediff: 0
nov.-13 10:39:31 Max_debug1 SWversion: 0.2p
Chambre 1er
Chambre 2eme
I've tried everything, delete devices and start installing them, but nothing.
I do not understand why both here.
Thanks for your help.
Posted: Tue Dec 09, 2014 11:05 am
by PuNiSHeR
Hello everyone,
So I found a track to the problem of valves that are not displayed.
I took a picture of my valves to try to understand where the problem is.
I valves with references here:
BC-RT-TRX-CYG - OK - Appears in HomeSeer 3
BC-RT-TRX-CYG-2 - Not OK - Do appear in HomeSeer 3
BC-RT-TRX-CYG-3 - OK - Appears in HomeSeer 3
Well, I hope it's going to go ahead and fix the bug.
Thank you.
Posted: Tue Dec 09, 2014 11:37 am
by PuNiSHeR
I just saw something in the logs.
The DeviceType is different:
Dec-09 9:14:55 Max_debug1 M: #Devices: 6 DeviceType 01 DeviceAddress: 680128 SN: KEQ0456371 DeviceName: Bathroom DeviceRoom: Name 1Room Bathroom
Dec-09 9:14:55 Max_debug1 M: #Devices: 6 DeviceType 01 DeviceAddress: 680107 SN: KEQ0456385 DeviceName: DeviceRoom Salon: Salon Name 2room
Dec-09 9:14:55 Max_debug1 M: #Devices: 6 DeviceType 01 DeviceAddress: 808028 SN: KEQ0917513 DeviceName: DeviceRoom Kitchen: Kitchen 3room Name
Dec-09 9:14:55 Max_debug1 M: #Devices: 6 DeviceType 02 DeviceAddress: 904613 SN: KEQ1035670 DeviceName: 1 Bedroom DeviceRoom: Name 4Room 1 Bedroom
Dec-09 9:14:55 Max_debug1 M: #Devices: 6 DeviceType 02 DeviceAddress: 904128 SN: KEQ1032468 DeviceName: 2nd Bedroom DeviceRoom: Name 5Room 2nd House
Dec-09 9:14:55 Max_debug1 M: #Devices: 6 DeviceType 01 DeviceAddress: 808383 SN: KEQ0917699 DeviceName: DeviceRoom Office: Office 6Room Name
The device type is 02 instead of 01 and the VB Script, 02 is not included.
I try to change the script to do take into account.
Posted: Wed Jan 07, 2015 5:15 pm
by wwolkers
PuNiSHeR wrote:The device type is 02 instead of 01 and the VB Script, 02 is not included.
The DeviceType 01 is a Radiator Thermostat
The DeviceType 02 is a Radiator Thermostat plus
Posted: Thu Jan 22, 2015 10:25 am
by PuNiSHeR
Thank you all.
I dropped HomeSeer 3 too many changes and it make me lose too much time.
I am selling my licenses Homeseer 3 Pro with RFXCOM plugin.
I'll stay on Homeseer Pro 2 and I will be going to Domoticz.
Posted: Sat Sep 19, 2015 9:33 am
by Meden199
I have a question about setting up a event for the EQ3 thermostat.
I made a event that runs "Max Trigger"
My question is what are the parameters that I have to use to change from "Auto" to "Manual" or from "Comfort" to "Eco"
Anyhelpd would be welcome.
Posted: Sun Jan 03, 2016 11:31 pm
by JoopK
Finaly I have a test version of HS3 running. I installed the HS3 script without issues but I receive an error when updating the cube:
jan-03 21:48:34 Database There were errors generated during the save of the database item. Please consult this log for more details and report any data loss to HomeSeer Technologies.
jan-03 21:48:34 Database ERROR, device Max! Heating Timezone failed to be updated or added to the database.
jan-03 21:48:34 Error SQL Exception adding device record (Ref=10) to the database: SQL logic error or missing database unrecognized token: "'CET", Code=1, Link=
jan-03 21:48:34 Max_debug Script complete
jan-03 21:48:34 Max_debug0 Create Valve Device: Y31
jan-03 21:48:34 Max_debug0 dev: Status
jan-03 21:48:34 xxx 43
jan-03 21:48:34 Max_debug0 dev: Mode
jan-03 21:48:34 xxx 42
jan-03 21:48:34 Max_debug0 dev: Setpoint
jan-03 21:48:34 xxx 41
jan-03 21:48:34 Max_debug0 dev: Temperature
jan-03 21:48:34 xxx 40
jan-03 21:48:34 Max_debug1 Firmware: 24
jan-03 21:48:34 Max_debug0 Create Wall Thermostat Device: Y27
jan-03 21:48:34 xxx 39
jan-03 21:48:34 xxx 38
jan-03 21:48:34 xxx 37
jan-03 21:48:34 xxx 36
jan-03 21:48:34 Max_debug1 Firmware: 16
jan-03 21:48:34 Max_debug0 Create Valve Device: Y23
jan-03 21:48:34 xxx 35
jan-03 21:48:34 xxx 34
jan-03 21:48:34 xxx 33
jan-03 21:48:34 xxx 32
jan-03 21:48:34 Max_debug0 Create Wall Thermostat Device: Y19
jan-03 21:48:34 xxx 31
jan-03 21:48:34 xxx 30
jan-03 21:48:34 xxx 29
jan-03 21:48:34 xxx 28
jan-03 21:48:34 Max_debug0 Create Wall Thermostat Device: Y15
jan-03 21:48:34 xxx 27
jan-03 21:48:34 xxx 26
jan-03 21:48:34 xxx 25
jan-03 21:48:34 xxx 24
jan-03 21:48:34 Max_debug0 Create Valve Device: Y11
jan-03 21:48:34 xxx 23
jan-03 21:48:34 xxx 22
jan-03 21:48:34 xxx 21
jan-03 21:48:34 xxx 20
jan-03 21:48:34 Max_debug0 Create Valve Device: Y7
jan-03 21:48:34 xxx 19
jan-03 21:48:34 xxx 18
jan-03 21:48:34 xxx 17
jan-03 21:48:34 xxx 16
jan-03 21:48:34 Max_debug0 Create Device: Y3
jan-03 21:48:34 xxx 15
jan-03 21:48:34 xxx 14
jan-03 21:48:34 xxx 13
jan-03 21:48:34 xxx 12
jan-03 21:48:34 Max Status device create - 99
jan-03 21:48:34 Max_Debug Main devices setup
jan-03 21:48:34 Max_Debug Stream closed
jan-03 21:48:34 Max_debug all items loaded
jan-03 21:48:34 Info H: Cubedate: 3-1-2016 21:50:00 systemtime: 3-1-2016 21:48:34 Datediff: -1
jan-03 21:48:29 Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/BLB_Max_monitor_HS3.vb
jan-03 21:48:29 Event Event Trigger "Max! Max! monitor"
jan-03 21:48:29 Event Event Max! Max! monitor triggered by the event page 'Run' button.
Any one encountered this before?
Posted: Sat Oct 08, 2016 7:17 pm
by mhn
The script stopped working om my HS3.
I think I found the reason.
My old devices look like this in advanced:
Device Type Internal Run Script, Type: Run Script: On String Change, SubType: Mode Device
I tried deleting some devices. Some of them was made again by running the script but now with:
Device Type Internal No API, Type: Type 0, SubType:
Seems like the Run Script function on devices has problems.
Can I run the script with parameters in HS3?
I tried a lot of syntaxes but untill now without any luck.
Regards
Morten
Posted: Sun Oct 16, 2016 10:50 am
by mhn
I anyone else gets this problem.
s:|1|win and s:|1|auto works as parameters i HomeSeer events.
